FIX: Prevent duplicate params for raw template theme handlebars helpers
diff --git a/app/models/theme_field.rb b/app/models/theme_field.rb
index 740eaf4..7620129 100644
--- a/app/models/theme_field.rb
+++ b/app/models/theme_field.rb
@@ -64,7 +64,7 @@ class ThemeField < ActiveRecord::Base
   validates :name, format: { with: /\A[a-z_][a-z0-9_-]*\z/i },
                    if: Proc.new { |field| ThemeField.theme_var_type_ids.include?(field.type_id) }
-  COMPILER_VERSION = 9
+  COMPILER_VERSION = 10
   belongs_to :theme
diff --git a/lib/theme_javascript_compiler.rb b/lib/theme_javascript_compiler.rb
index e01d7a6..7abe3f7 100644
--- a/lib/theme_javascript_compiler.rb
+++ b/lib/theme_javascript_compiler.rb
@@ -64,11 +64,13 @@ class ThemeJavascriptCompiler
       function manipulateNode(node) {
         // Magically add theme id as the first param for each of these helpers
         if (node.path.parts && ["theme-i18n", "theme-prefix", "theme-setting"].includes(node.path.parts[0])) {
-          node.params.unshift({
-            type: "NumberLiteral",
-            value: #{@theme_id},
-            original: #{@theme_id}
+          if(node.params.length === 1){
+            node.params.unshift({
+              type: "NumberLiteral",
+              value: #{@theme_id},
+              original: #{@theme_id}
         // Override old themeSetting syntax when it's in its own node
diff --git a/spec/lib/theme_javascript_compiler_spec.rb b/spec/lib/theme_javascript_compiler_spec.rb
index 4bb011d..3ae1fd1 100644
--- a/spec/lib/theme_javascript_compiler_spec.rb
+++ b/spec/lib/theme_javascript_compiler_spec.rb
@@ -62,6 +62,12 @@ describe ThemeJavascriptCompiler do
       expect(render("{{dummy-helper themeSettings.setting_key}}")).
         to eq('dummy(setting(22:setting_key))')
+    it "doesn't duplicate number parameter inside {{each}}" do
+      expect(compiler.compile("{{#each item as |test test2|}}{{theme-setting 'setting_key'}}{{/each}}")).
+        to include('{"name":"theme-setting","hash":{},"hashTypes":{},"hashContexts":{},"types":["NumberLiteral","StringLiteral"]')
+      # Fail would be if theme-setting is defined with types:["NumberLiteral","NumberLiteral","StringLiteral"]
+    end
   describe ThemeJavascriptCompiler::EmberTemplatePrecompiler do
GitHub sha: 95b5c589
