FIX: Prevent low score flags from auto-closing a topic if the reviewable default visibility is higher than "low" (PR #9375)
GitHub
The title of this pull request changed from “FIX: Prevent low score flags from auto-closing a topic if the reviewable default visibility is higher than low” to "FIX: Prevent low score flags from auto-closing a topic if the reviewable default visibility is higher than “low”
Awesome, thanks!
