FIX: Prevent thumbnail gen if image too large (#10247)
It’s possible through an import or other means to have images larger than the current max allowed image size in the db.
If this happens the thumbnail generation job will keep running indefinitely trying to download a new copy of the original but discarding it because it is larger than the max_file_size eventually causing this error
Job exception: undefined method path’ for nil:NilClass`
because the newly downloaded image is now nil.
This fix stops the enqueuing of the GenerateTopicThumbnails job for all images that happen to be larger than the max image size.
diff --git a/app/models/topic.rb b/app/models/topic.rb
index 4088ab4..d78533f 100644
--- a/app/models/topic.rb
+++ b/app/models/topic.rb
@@ -52,6 +52,7 @@ class Topic < ActiveRecord::Base
   def thumbnail_info(enqueue_if_missing: false, extra_sizes: [])
     return nil unless original = image_upload
+    return nil unless original.filesize < SiteSetting.max_image_size_kb
     return nil unless original.read_attribute(:width) && original.read_attribute(:height)
     infos = []
@@ -94,6 +95,7 @@ class Topic < ActiveRecord::Base
   def generate_thumbnails!(extra_sizes: [])
     return nil unless SiteSetting.create_thumbnails
     return nil unless original.width && original.height
     extra_sizes = [] unless extra_sizes.kind_of?(Array)
@@ -111,6 +113,7 @@ class Topic < ActiveRecord::Base
     if thumbnail.nil? &&
         image_upload &&
         SiteSetting.create_thumbnails &&
+        image_upload.filesize < SiteSetting.max_image_size_kb &&
         enqueue_if_missing &&
         Discourse.redis.set(thumbnail_job_redis_key([]), 1, nx: true, ex: 1.minute)
       Jobs.enqueue(:generate_topic_thumbnails, { topic_id: id })
diff --git a/spec/models/topic_thumbnail_spec.rb b/spec/models/topic_thumbnail_spec.rb
index 84c8298..9248124 100644
--- a/spec/models/topic_thumbnail_spec.rb
+++ b/spec/models/topic_thumbnail_spec.rb
@@ -5,6 +5,9 @@ describe "TopicThumbnail" do
   let(:upload1) { Fabricate(:image_upload, width: 5000, height: 5000) }
   let(:topic) { Fabricate(:topic, image_upload: upload1) }
+  let(:upload2) { Fabricate(:image_upload, width: 5000, height: 5000, filesize: 8000) }
+  let(:topic2) { Fabricate(:topic, image_upload: upload2) }
   before do
     SiteSetting.create_thumbnails = true
     topic.generate_thumbnails!(extra_sizes: nil)
@@ -15,6 +18,16 @@ describe "TopicThumbnail" do
     expect(topic.topic_thumbnails.length).to eq(1)
+  it "does not enque job if original image is too large" do
+    SiteSetting.create_thumbnails = true
+    topic2.generate_thumbnails!(extra_sizes: nil)
+    TopicThumbnail.ensure_consistency!
+    topic2.reload
+    expect(topic2.topic_thumbnails.length).to eq(0)
+  end
   it "cleans up deleted uploads" do
     upload1.delete
GitHub sha: 1e9ce511
This commit appears in #10247 which was merged by SamSaffron.
