FIX: prevents exception when text input is nil (#12922)
nil was converted to “” and the matching regex would return and then be converted to nil with max usage.
Example exception:
NoMethodError (undefined method `<=' for nil:NilClass)
lib/text_sentinel.rb:71:in `seems_unpretentious?'
lib/validators/quality_title_validator.rb:13:in `validate_each'
lib/topic_creator.rb:25:in `valid?'
diff --git a/lib/text_sentinel.rb b/lib/text_sentinel.rb
index 7205357..f720e1b 100644
--- a/lib/text_sentinel.rb
+++ b/lib/text_sentinel.rb
@@ -68,7 +68,9 @@ class TextSentinel
   def seems_unpretentious?
     return true if skipped_locale.include?(SiteSetting.default_locale)
     # Don't allow super long words if there is a word length maximum
-    @opts[:max_word_length].blank? || @text.split(/\s|\/|-|\.|:/).map(&:size).max <= @opts[:max_word_length]
+    @opts[:max_word_length].blank? ||
+    (@text.split(/\s|\/|-|\.|:/).map(&:size).max || 0) <= @opts[:max_word_length]
   def seems_quiet?
diff --git a/spec/components/text_sentinel_spec.rb b/spec/components/text_sentinel_spec.rb
index d14a8bf..2676a01 100644
--- a/spec/components/text_sentinel_spec.rb
+++ b/spec/components/text_sentinel_spec.rb
@@ -61,6 +61,18 @@ describe TextSentinel do
+    it "uses a sensible min entropy value when min body length is less than min entropy" do
+      SiteSetting.min_post_length = 3
+      SiteSetting.body_min_entropy = 7
+      expect(TextSentinel.body_sentinel('Yup')).to be_valid
+    end
+    it "uses a sensible min entropy value when min pm body length is less than min entropy" do
+      SiteSetting.min_post_length = 5
+      SiteSetting.min_personal_message_post_length = 3
+      expect(TextSentinel.body_sentinel('Lol', private_message: true)).to be_valid
+    end
   context "validity" do
@@ -144,19 +156,9 @@ describe TextSentinel do
-  context 'body_sentinel' do
-    it "uses a sensible min entropy value when min body length is less than min entropy" do
-      SiteSetting.min_post_length = 3
-      SiteSetting.body_min_entropy = 7
-      expect(TextSentinel.body_sentinel('Yup')).to be_valid
-    end
-    it "uses a sensible min entropy value when min pm body length is less than min entropy" do
-      SiteSetting.min_post_length = 5
-      SiteSetting.min_personal_message_post_length = 3
-      expect(TextSentinel.body_sentinel('Lol', private_message: true)).to be_valid
+  context 'seems_unpretentious?' do
+    it 'works with nil title' do
+      expect(TextSentinel.title_sentinel(nil).seems_unpretentious?).to eq(true)
GitHub sha: d16a39dc
This commit appears in #12922 which was approved by ZogStriP. It was merged by jjaffeux.
