FIX: problem when [] custom field is send (#13573)
FIX: problem when custom field is send (#13573)
Multiselect data can be saved but when all are removed then data are not cleared
Ajax function is removing an empty array from request data. In that case, we should change [] to null.
We need that empty values to properly empty data.
diff --git a/app/assets/javascripts/discourse/app/controllers/preferences/profile.js b/app/assets/javascripts/discourse/app/controllers/preferences/profile.js
index fb31cf3..444de26 100644
--- a/app/assets/javascripts/discourse/app/controllers/preferences/profile.js
+++ b/app/assets/javascripts/discourse/app/controllers/preferences/profile.js
@@ -86,21 +86,29 @@ export default Controller.extend({
       this.model.set("user_option.timezone", moment.tz.guess());
-    save() {
-      this.set("saved", false);
+    _updateUserFields() {
       const model = this.model,
         userFields = this.userFields;
-      // Update the user fields
       if (!isEmpty(userFields)) {
         const modelFields = model.get("user_fields");
         if (!isEmpty(modelFields)) {
           userFields.forEach(function (uf) {
-            modelFields[uf.get("field.id").toString()] = uf.get("value");
+            const value = uf.get("value");
+            modelFields[uf.get("field.id").toString()] = isEmpty(value)
+              ? null
+              : value;
+    save() {
+      this.set("saved", false);
+      const model = this.model;
+      // Update the user fields
+      this.send("_updateUserFields");
       return model
         .save(this.saveAttrNames)
diff --git a/app/assets/javascripts/discourse/tests/unit/controllers/preferences-profile-test.js b/app/assets/javascripts/discourse/tests/unit/controllers/preferences-profile-test.js
new file mode 100644
index 0000000..bd0f962
--- /dev/null
+++ b/app/assets/javascripts/discourse/tests/unit/controllers/preferences-profile-test.js
@@ -0,0 +1,41 @@
+import { discourseModule } from "discourse/tests/helpers/qunit-helpers";
+import { test } from "qunit";
+import EmberObject from "@ember/object";
+import User from "discourse/models/user";
+discourseModule("Unit | Controller | preferences/profile", function () {
+  test("prepare custom field data", function (assert) {
+    const controller = this.getController("preferences/profile", {
+      model: User.create({
+        id: 70,
+        second_factor_enabled: true,
+        is_anonymous: true,
+        user_fields: {
+          field_1: "1",
+          field_2: "2",
+          field_3: "3",
+      currentUser: {
+        id: 1234,
+    controller.set("userFields", [
+      EmberObject.create({ value: "2", field: { id: "field_1" } }),
+      EmberObject.create({ value: null, field: { id: "field_2" } }),
+      EmberObject.create({ value: [], field: { id: "field_3" } }),
+    controller.send("_updateUserFields");
+    assert.equal(
+      controller.model.user_fields.field_1,
+      "2",
+      "updates string value"
+    assert.equal(controller.model.user_fields.field_2, null, "updates null");
+    assert.equal(
+      controller.model.user_fields.field_3,
+      null,
+      "updates empty array as null"
GitHub sha: 5c43f9a3a3012167041d334d2db5f73718a49c47
This commit appears in #13573 which was approved by tgxworld. It was merged by lis2.
