FIX: properly ban non human users from draft system
Previously we had a partial fix in place where non human users were not allowed draft sequences, this left edges around where non human users asked for drafts yet had none.
For example system could already have a few drafts in place.
This also removes and extensibility point we added that is not in use
diff --git a/app/models/draft.rb b/app/models/draft.rb
index a2fba62..2165a0a 100644
--- a/app/models/draft.rb
+++ b/app/models/draft.rb
@@ -10,6 +10,8 @@ class Draft < ActiveRecord::Base
   class OutOfSequence < StandardError; end
   def self.set(user, key, sequence, data, owner = nil)
+    return 0 if !User.human_user_id?(user.id)
     if SiteSetting.backup_drafts_to_pm_length > 0 && SiteSetting.backup_drafts_to_pm_length < data.length
       backup_draft(user, key, sequence, data)
@@ -94,6 +96,7 @@ class Draft < ActiveRecord::Base
   def self.get(user, key, sequence)
+    return if !user || !user.id || !User.human_user_id?(user.id)
     opts = {
       user_id: user.id,
@@ -128,6 +131,8 @@ class Draft < ActiveRecord::Base
   def self.clear(user, key, sequence)
     current_sequence = DraftSequence.current(user, key)
     # bad caller is a reason to complain
diff --git a/app/models/draft_sequence.rb b/app/models/draft_sequence.rb
index 681a8bc..b79f3c9 100644
--- a/app/models/draft_sequence.rb
+++ b/app/models/draft_sequence.rb
@@ -2,10 +2,12 @@
 class DraftSequence < ActiveRecord::Base
   def self.next!(user, key)
+    return nil if !user
     user_id = user
     user_id = user.id unless user.is_a?(Integer)
-    return 0 if invalid_user_id?(user_id)
+    return 0 if !User.human_user_id?(user_id)
     h = { user_id: user_id, draft_key: key }
     c = DraftSequence.find_by(h)
@@ -18,27 +20,17 @@ class DraftSequence < ActiveRecord::Base
   def self.current(user, key)
-    return nil unless user
     user_id = user
     # perf critical path
     r, _ = DB.query_single('select sequence from draft_sequences where user_id = ? and draft_key = ?', user_id, key)
     r.to_i
-  cattr_accessor :plugin_ignore_draft_sequence_callbacks
-  self.plugin_ignore_draft_sequence_callbacks = {}
-  def self.invalid_user_id?(user_id)
-    user_id < 0 || self.plugin_ignore_draft_sequence_callbacks.any? do |plugin, callback|
-      plugin.enabled? ? callback.call(user_id) : false
-    end
-  end
-  private_class_method :invalid_user_id?
 # == Schema Information
diff --git a/app/models/user.rb b/app/models/user.rb
index d9678d1..0147c62 100644
--- a/app/models/user.rb
+++ b/app/models/user.rb
@@ -306,8 +306,12 @@ class User < ActiveRecord::Base
     fields.uniq
+  def self.human_user_id?(user_id)
+    user_id > 0
+  end
   def human?
-    self.id > 0
+    User.human_user_id?(self.id)
   def bot?
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index ab48f7c..0390216 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -405,15 +405,6 @@ class Plugin::Instance
     SeedFu.fixture_paths.concat(paths)
-  # Applies to all sites in a multisite environment. Block is not called if
-  # plugin is not enabled. Block is called with `user_id` and has to return a
-  # boolean based on whether the given `user_id` should be ignored.
-  def register_ignore_draft_sequence_callback(&block)
-    reloadable_patch do |plugin|
-      ::DraftSequence.plugin_ignore_draft_sequence_callbacks[plugin] = block
-    end
-  end
   def listen_for(event_name)
     return unless self.respond_to?(event_name)
     DiscourseEvent.on(event_name, &self.method(event_name))
diff --git a/spec/models/draft_spec.rb b/spec/models/draft_spec.rb
index b2066b0..980f079 100644
--- a/spec/models/draft_spec.rb
+++ b/spec/models/draft_spec.rb
@@ -12,6 +12,22 @@ describe Draft do
     Fabricate(:post)
+  context 'system user' do
+    it "can not set drafts" do
+      # fake a sequence
+      DraftSequence.create!(user_id: Discourse.system_user.id, draft_key: "abc", sequence: 10)
+      seq = Draft.set(Discourse.system_user, "abc", 0, { reply: 'hi' }.to_json)
+      expect(seq).to eq(0)
+      draft = Draft.get(Discourse.system_user, "abc", 0)
+      expect(draft).to eq(nil)
+      draft = Draft.get(Discourse.system_user, "abc", 1)
+    end
+  end
   context 'backup_drafts_to_pm_length' do
     it "correctly backs up drafts to a personal message" do
       SiteSetting.backup_drafts_to_pm_length = 1
GitHub sha: fc97f7e0
