FIX: Properly render server side plugin outlets (PR #8106)
The behavior of the render helper method changed in Rails 6 so now the method doesn’t render the template and return the output, instead it just returns the file content as-is. Context: https://meta.discourse.org/t/discourse-sitemap-plugin/40348/134?u=osama
GitHub
You’ve signed the CLA, OsamaSayegh. Thank you! This pull request is ready for review.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
