FIX: properly unassign topics if there are no **more** flags to handle
FIX: properly unassign topics if there are no more flags to handle
From 5800f768f555c0262b1428271fd43c332bd484ba Mon Sep 17 00:00:00 2001
From: =?UTF-8?q?R=C3=A9gis=20Hanol?= <regis@hanol.fr>
Date: Tue, 14 Aug 2018 18:20:00 +0200
Subject: [PATCH] FIX: properly unassign topics if there are no **more** flags
 to handle
index 38a59ca..65db180 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -217,7 +217,8 @@ after_initialize do
   on(:flag_reviewed) do |post|
     if SiteSetting.assign_locks_flags? &&
       post.topic &&
-      FlagQuery.flagged_post_actions(topic_id: post.topic.id).count == 0
+      FlagQuery.flagged_post_actions(topic_id: post.topic_id, filter: "old").count > 0 &&
+      FlagQuery.flagged_post_actions(topic_id: post.topic_id).count == 0
       assigner = ::TopicAssigner.new(post.topic, Discourse.system_user)
       assigner.unassign
GitHub
I think we should update our test cases to prevent this from regressing.
Another bigger question is why “flag_reviewed” is firing when you delete a post with zero flags…
@tgxworld I was actually waiting to investigate what @SamSaffron noted before writing a spec :wink:
You are receiving this because you authored the thread.
Reply to this email directly, view it on GitHub, or mute the thread.
It’s now properly fixed in FIX: don't trigger 'flag_reviewed' when no flags were reviewed · discourse/discourse@93201d8 · GitHub :ok_hand:
