FIX: public_file_server.enabled is false in test (#8192)
After a small conversation, we decided that we can set public_file_server.enabled to false in the test environment to have the same value as production.
diff --git a/config/environments/test.rb b/config/environments/test.rb
index da7b6f2ef3..4ff6594e90 100644
--- a/config/environments/test.rb
+++ b/config/environments/test.rb
@@ -10,7 +10,7 @@ Discourse::Application.configure do
   config.cache_classes = true
   # Configure static asset server for tests with Cache-Control for performance
-  config.public_file_server.enabled = true
+  config.public_file_server.enabled = false
   # don't consider reqs local so we can properly handle exceptions like we do in prd
   config.consider_all_requests_local       = false
diff --git a/spec/requests/uploads_controller_spec.rb b/spec/requests/uploads_controller_spec.rb
index cb738c73ea..0d3231568c 100644
--- a/spec/requests/uploads_controller_spec.rb
+++ b/spec/requests/uploads_controller_spec.rb
@@ -266,7 +266,6 @@ describe UploadsController do
     it 'returns 200 when js file' do
-      ActionDispatch::FileHandler.any_instance.stubs(:match?).returns(false)
       upload = upload_file("test.js", "themes")
       get upload.url
       expect(response.status).to eq(200)
GitHub sha: 5a8fdd02
Revert "FIX: public_file_server.enabled is false in test (#8192)" (#8196)
