FIX: Queued Posts were not saving tags properly
diff --git a/lib/new_post_manager.rb b/lib/new_post_manager.rb
index c99abea..b5de841 100644
--- a/lib/new_post_manager.rb
+++ b/lib/new_post_manager.rb
@@ -183,7 +183,7 @@ class NewPostManager
     reviewable = ReviewableQueuedPost.new(
       created_by: @user,
-      payload: { raw: @args[:raw] },
+      payload: { raw: @args[:raw], tags: @args[:tags] },
       topic_id: @args[:topic_id],
       reviewable_by_moderator: true
diff --git a/spec/components/new_post_manager_spec.rb b/spec/components/new_post_manager_spec.rb
index bc35f00..b00def4 100644
--- a/spec/components/new_post_manager_spec.rb
+++ b/spec/components/new_post_manager_spec.rb
@@ -268,7 +268,8 @@ describe NewPostManager do
       manager = NewPostManager.new(
         topic.user,
         raw: 'to the handler I say enqueue me!',
-        title: 'this is the title of the queued post'
+        title: 'this is the title of the queued post',
+        tags: ['hello', 'world']
       result = manager.perform
@@ -280,6 +281,7 @@ describe NewPostManager do
       expect(reviewable.reviewable_scores).to be_present
       expect(reviewable.score).to eq(20.5)
       expect(reviewable.reviewable_by_moderator?).to eq(true)
+      expect(reviewable.payload['tags']).to eq(['hello', 'world'])
       expect(result.action).to eq(:enqueued)
       expect(result).to be_success
       expect(result.pending_count).to eq(1)
GitHub sha: 8181ad64
