FIX: Rails 6 multisite migrations and plugin migrations
Prior to this change plugin migrations were not working and multisite migrations not working.
Rails internals changed so we need to account for it.
Specifically semantics of db:migrate
in rails changed so it is sort of
a “multisite:migrate”.
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index 96bdcc3..4a3211d 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -516,7 +516,7 @@ class Plugin::Instance
Rake.add_rakelib(File.dirname(path) + "/lib/tasks")
# Automatically include migrations
- migration_paths = Rails.configuration.paths["db/migrate"]
+ migration_paths = ActiveRecord::Migrator.migrations_paths
migration_paths << File.dirname(path) + "/db/migrate"
unless Discourse.skip_post_deployment_migrations?
diff --git a/lib/tasks/db.rake b/lib/tasks/db.rake
index afc470f..03bbcee 100644
--- a/lib/tasks/db.rake
+++ b/lib/tasks/db.rake
@@ -48,8 +48,16 @@ task 'db:drop' => [:load_config] do |_, args|
+begin
+ Rake::Task["db:migrate"].clear
+end
# we need to run seed_fu every time we run rake db:migrate
task 'db:migrate' => ['environment', 'set_locale'] do |_, args|
+ ActiveRecord::Tasks::DatabaseTasks.migrate
+ Rake::Task['db:_dump'].invoke
SeedFu.seed(DiscoursePluginRegistry.seed_paths)
GitHub sha: 025d4ee9
