FIX: randomly failing user_spec (PR #9754)
When we evaluate update_last_seen! we relay on Redis to not run that code too often
https://github.com/discourse/discourse/blob/master/app/models/user.rb#L753
The problem is that not all specs which are running update_last_seen! are cleaning after themselves
    after do
      Discourse.redis.flushall
For examples specs in that block https://github.com/discourse/discourse/blob/master/spec/models/user_spec.rb#L901
So it can be replicated when you run a few times bundle exec rspec ./spec/models/user_spec.rb -e "should not update the first seen value if it doesn't exist" -e "should have 0 for days_visited"
We should flush Redis after each spec which is evaluating update_last_seen!
GitHub
The title of this pull request changed from “FIX: randomly falling user_spec” to "FIX: randomly failing user_spec
I worry a bit about flushall, I wonder if we can be more explicit, at least the test is aware of exactly what it mucked with… I guess I am okish with this cause we do it elsewhere
@SamSaffron you are right, it may create random failure somewhere else. Let me fix it to drop that specific key
