FIX: re-exec code was broken
  • BASH_ARGV is only used in extended debugging mode
diff --git a/launcher b/launcher
index 4c9ebb7..0153305 100755
--- a/launcher
+++ b/launcher
@@ -23,6 +23,9 @@ usage () {
   exit 1
+# for potential re-exec later
+SAVED_ARGV=("$@")
 command=$1
 config=$2
@@ -788,14 +791,11 @@ case "$command" in
           echo "Launcher is up-to-date"
         elif [ $LOCAL = $BASE ]; then
-          echo "Updating Launcher"
+          echo "Updating Launcher..."
           git pull || (echo 'failed to update' && exit 1)
-          for (( i=${#BASH_ARGV[@]}-1,j=0; i>=0,j<${#BASH_ARGV[@]}; i--,j++ ))
-          do
-            args[$j]=${BASH_ARGV[$i]}
-          done
-          exec bash $0 "${args[@]}" # $@ is empty, because of shift at the beginning. Use BASH_ARGV instead.
+          echo "Launcher updated, restarting..."
+          exec "$0" "${SAVED_ARGV[@]}"
         elif [ $REMOTE = $BASE ]; then
           echo "Your version of Launcher is ahead of origin"
GitHub sha: 13b0817c
