FIX: Refactor broke wizard
diff --git a/app/assets/javascripts/discourse-common/addon/lib/icon-library.js b/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
index 0bf8d86..acbd7b1 100644
--- a/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
+++ b/app/assets/javascripts/discourse-common/addon/lib/icon-library.js
@@ -1,12 +1,12 @@
 import I18n from "I18n";
 import { h } from "virtual-dom";
 import attributeHook from "discourse-common/lib/attribute-hook";
-import Session from "discourse/models/session";
 const SVG_NAMESPACE = "http://www.w3.org/2000/svg";
 let _renderers = [];
 let warnMissingIcons = true;
+let _iconList;
 const REPLACEMENTS = {
   "d-tracking": "bell",
@@ -110,12 +110,13 @@ function iconClasses(icon, params) {
   return classNames;
+export function setIconList(iconList) {
+  _iconList = iconList;
 function warnIfMissing(id) {
-  if (warnMissingIcons) {
-    let iconList = Session.currentProp("svgIconList");
-    if (iconList && iconList.indexOf(id) === -1) {
-      console.warn(`The icon "${id}" is missing from the SVG subset.`); // eslint-disable-line no-console
+  if (warnMissingIcons && _iconList && _iconList.indexOf(id) === -1) {
+    console.warn(`The icon "${id}" is missing from the SVG subset.`); // eslint-disable-line no-console
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
index 6695428..86e9354 100644
--- a/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
+++ b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
@@ -10,6 +10,7 @@ import {
 } from "discourse-common/config/environment";
 import { setupURL, setupS3CDN } from "discourse-common/lib/get-url";
 import deprecated from "discourse-common/lib/deprecated";
+import { setIconList } from "discourse-common/lib/icon-library";
 export default {
@@ -100,7 +101,7 @@ export default {
     Session.currentProp("svgSpritePath", setupData.svgSpritePath);
     if (isDevelopment()) {
-      Session.currentProp("svgIconList", setupData.svgIconList);
+      setIconList(setupData.svgIconList);
     if (setupData.s3BaseUrl) {
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/svg-sprite-fontawesome.js b/app/assets/javascripts/discourse/app/pre-initializers/svg-sprite-fontawesome.js
index 72aff84..686a9e6 100644
--- a/app/assets/javascripts/discourse/app/pre-initializers/svg-sprite-fontawesome.js
+++ b/app/assets/javascripts/discourse/app/pre-initializers/svg-sprite-fontawesome.js
@@ -2,6 +2,7 @@ import { loadSprites } from "discourse/lib/svg-sprite-loader";
 export default {
+  after: "discourse-bootstrap",
   initialize(container) {
     let session = container.lookup("session:main");
GitHub sha: e2e51ee3
