FIX: Refine dismiss notification confirmation (PR #15017)
Based on /t/44871 I’ve made some modifications to the dialog mostly for copy and consistency.
Note that I had the choice to use bootbox’s ability to add an icon to a button, but I see that there are zero occurrences of this usage in the codebase, so I made a decision not to introduce something new, and re-introduce the template instead.
GitHub
I am going to be annoying, but you should use the I18n.t helpers in the tests as well, otherwise this test will break if someone updates that text
Looks great, just a minor change.
Same here, I18n.t
Great! I hadn’t noticed that, thanks!
Hmm, thinking about it, shouldn’t the test break if someone updates that text? If the implementation states to use a key that doesn’t exist, it will show up as jibberish and the test won’t catch it.
As spoken, I’ll make the change for consistency!
Do we have many/any other alerts that don’t say what’s the operation you’re accepting/dismissing?
@CvX what do you mean? This alert only comes up after pressing the Dismiss Notifications button when you have > 1 green (important) notifications. I think it’s pretty clear what you are accepting with this modal, and the copy was discussed on the internal topic too.
It often is pretty clear, but we still reiterate (in all “are you sure” modals) what the action is.
I wanna prevent more bikeshedding, so have a look /t/44871
The title of this pull request changed from “Refine dismiss notification confirmation” to "FIX: Refine dismiss notification confirmation
