Fix regression due to f80e6a37a9d748f43047141b18986f6386444bc9.
diff --git a/launcher b/launcher
index dad89fc..30245c8 100755
--- a/launcher
+++ b/launcher
@@ -55,7 +55,7 @@ while [ ${#} -gt 0 ]; do
   shift 1
 done
-if [[ -z $config ]]; then
+if [ -z "$command" -o -z "$config" -a "$command" != "cleanup" ]; then
   usage
   exit 1
 fi
@@ -451,10 +451,6 @@ fi
   exit 0
-if [ -z "$command" -a -z "$config" ]; then
-  usage
-fi
 if [ ! "$command" == "setup" ]; then
   if [[ ! -e $config_file ]]; then
     echo "Config file was not found, ensure $config_file exists"
@@ -674,8 +670,6 @@ run_bootstrap() {
   $docker_path rm `cat $cidbootstrap` && rm $cidbootstrap
 case "$command" in
   bootstrap)
       run_bootstrap
GitHub sha: ea4428d7
