FIX: Remove additional setting check for uppy-upload (#13867)
Because the enable_s3_uploads setting may be false for some sites but GlobalSetting.use_s3? is true, we need to remove this additional check in uppy-upload. The hidden enable_direct_s3_uploads setting is sufficient.
diff --git a/app/assets/javascripts/discourse/app/mixins/uppy-upload.js b/app/assets/javascripts/discourse/app/mixins/uppy-upload.js
index 0408b88..d6b5377 100644
--- a/app/assets/javascripts/discourse/app/mixins/uppy-upload.js
+++ b/app/assets/javascripts/discourse/app/mixins/uppy-upload.js
@@ -151,10 +151,8 @@ export default Mixin.create({
       this._reset();
-    if (
-      this.siteSettings.enable_s3_uploads &&
-      this.siteSettings.enable_direct_s3_uploads // hidden setting like enable_experimental_image_uploader
+    // hidden setting like enable_experimental_image_uploader
+    if (this.siteSettings.enable_direct_s3_uploads) {
       this._useS3Uploads();
     } else {
       this._useXHRUploads();
GitHub sha: 84e77e9078d34f1024b3002fea7533db5a8ce7d9
This commit appears in #13867 which was approved by blake. It was merged by martin.
