FIX: remove dependency on present? in distributed_mutex lib
diff --git a/lib/distributed_mutex.rb b/lib/distributed_mutex.rb
index 19f8b5d..d9a1879 100644
--- a/lib/distributed_mutex.rb
+++ b/lib/distributed_mutex.rb
@@ -83,7 +83,7 @@ class DistributedMutex
     current_expire_time = redis.get key
-    if current_expire_time.present? && current_expire_time.to_i > now
+    if current_expire_time && current_expire_time.to_i > now
       redis.unwatch
       got_lock = false
@@ -94,7 +94,7 @@ class DistributedMutex
           redis.expire key, validity
-      got_lock = result.present?
+      got_lock = !result.nil?
     [got_lock, expire_time]
@@ -109,7 +109,7 @@ class DistributedMutex
         redis.multi do
           redis.del key
-      return result.present?
+      return !result.nil?
     else
       redis.unwatch
       return false
GitHub sha: 5f87089b
Do you have any thoughts on how to prevent this happening in the future?
We could make a gem for this, it may be a bit overkill
