FIX: remove deperecated Minitest global assertions
diff --git a/spec/lib/message_bus/assets/asset_encoding_spec.rb b/spec/lib/message_bus/assets/asset_encoding_spec.rb
index 7a154ab..ace275d 100644
--- a/spec/lib/message_bus/assets/asset_encoding_spec.rb
+++ b/spec/lib/message_bus/assets/asset_encoding_spec.rb
@@ -5,7 +5,7 @@ asset_file_names = asset_file_paths.map { |e| File.basename(e) }
 describe asset_file_names do
   it 'should contain .js files' do
-    asset_file_names.must_include('message-bus.js')
+    _(asset_file_names).must_include('message-bus.js')
diff --git a/spec/lib/message_bus/backend_spec.rb b/spec/lib/message_bus/backend_spec.rb
index 989e5fb..ab2c31b 100644
--- a/spec/lib/message_bus/backend_spec.rb
+++ b/spec/lib/message_bus/backend_spec.rb
@@ -13,7 +13,7 @@ describe PUB_SUB_CLASS do
   describe "API parity" do
     it "has the same public methods as the base class" do
-      @bus.public_methods.sort.must_equal MessageBus::Backends::Base.new(MESSAGE_BUS_CONFIG).public_methods.sort
+      _(@bus.public_methods.sort).must_equal MessageBus::Backends::Base.new(MESSAGE_BUS_CONFIG).public_methods.sort
@@ -21,14 +21,14 @@ describe PUB_SUB_CLASS do
     @bus.publish "/foo", "bar"
     @bus.publish "/foo", "baz"
-    @bus.backlog("/foo", 0).to_a.must_equal [
+    _(@bus.backlog("/foo", 0).to_a).must_equal [
       MessageBus::Message.new(1, 1, '/foo', 'bar'),
       MessageBus::Message.new(2, 2, '/foo', 'baz')
   it "should initialize with max_backlog_size" do
-    PUB_SUB_CLASS.new({}, 2000).max_backlog_size.must_equal 2000
+    _(PUB_SUB_CLASS.new({}, 2000).max_backlog_size).must_equal 2000
   it "should truncate channels correctly" do
@@ -42,7 +42,7 @@ describe PUB_SUB_CLASS do
       @bus.publish "/foo", t
-    @bus.backlog("/foo").to_a.must_equal [
+    _(@bus.backlog("/foo").to_a).must_equal [
       MessageBus::Message.new(3, 3, '/foo', 'three'),
       MessageBus::Message.new(4, 4, '/foo', 'four'),
@@ -54,14 +54,14 @@ describe PUB_SUB_CLASS do
     @bus.publish "/bar", "two"
     @bus.publish "/baz", "three"
-    @bus.global_backlog.length.must_equal 2
+    _(@bus.global_backlog.length).must_equal 2
   it "should be able to grab a message by id" do
     id1 = @bus.publish "/foo", "bar"
     id2 = @bus.publish "/foo", "baz"
-    @bus.get_message("/foo", id2).must_equal MessageBus::Message.new(2, 2, "/foo", "baz")
-    @bus.get_message("/foo", id1).must_equal MessageBus::Message.new(1, 1, "/foo", "bar")
+    _(@bus.get_message("/foo", id2)).must_equal MessageBus::Message.new(2, 2, "/foo", "baz")
+    _(@bus.get_message("/foo", id1)).must_equal MessageBus::Message.new(1, 1, "/foo", "bar")
   it "should have the correct number of messages for multi threaded access" do
@@ -80,13 +80,13 @@ describe PUB_SUB_CLASS do
   it "should be able to encode and decode messages properly" do
     m = MessageBus::Message.new 1, 2, '||', '||'
-    MessageBus::Message.decode(m.encode).must_equal m
+    _(MessageBus::Message.decode(m.encode)).must_equal m
   it "should allow us to get last id on a channel" do
-    @bus.last_id("/foo").must_equal 0
+    _(@bus.last_id("/foo")).must_equal 0
     @bus.publish("/foo", "one")
-    @bus.last_id("/foo").must_equal 1
+    _(@bus.last_id("/foo")).must_equal 1
   describe "readonly" do
@@ -107,16 +107,16 @@ describe PUB_SUB_CLASS do
       3.times do
         result = @bus.publish "/foo", "bar"
         assert_nil result
-        Thread.list.length.must_equal(current_threads_length + 1)
+        _(Thread.list.length).must_equal(current_threads_length + 1)
       @bus.pub_redis.slaveof "no", "one"
       sleep 0.01
       (Thread.list - current_threads).each(&:join)
-      Thread.list.length.must_equal current_threads_length
+      _(Thread.list.length).must_equal current_threads_length
-      @bus.backlog("/foo", 0).map(&:data).must_equal ["bar", "bar"]
+      _(@bus.backlog("/foo", 0).map(&:data)).must_equal ["bar", "bar"]
@@ -129,8 +129,8 @@ describe PUB_SUB_CLASS do
     expected_backlog_size += 1
-    @bus.global_backlog.length.must_equal expected_backlog_size
-    @bus.backlog("/foo", 0).length.must_equal expected_backlog_size
+    _(@bus.global_backlog.length).must_equal expected_backlog_size
+    _(@bus.backlog("/foo", 0).length).must_equal expected_backlog_size
     sleep 1.25 # Should now be at time =~ 1.25s. Our backlog should have expired by now.
     expected_backlog_size = 0
@@ -138,15 +138,15 @@ describe PUB_SUB_CLASS do
     case MESSAGE_BUS_CONFIG[:backend]
     when :postgres
       # Force triggering backlog expiry: postgres backend doesn't expire backlogs on a timer, but at publication time.
-      @bus.global_backlog.length.wont_equal expected_backlog_size
-      @bus.backlog("/foo", 0).length.wont_equal expected_backlog_size
+      _(@bus.global_backlog.length).wont_equal expected_backlog_size
+      _(@bus.backlog("/foo", 0).length).wont_equal expected_backlog_size
     # Assert that the backlog did expire, and now has only the new publication in it.
     sleep 0.75 # Should now be at time =~ 2s
@@ -166,8 +166,8 @@ describe PUB_SUB_CLASS do
     else
       # Assert that the backlog did not expire, and has all of our publications since the last expiry.
   it "can set backlog age on publish" do
@@ -181,8 +181,8 @@ describe PUB_SUB_CLASS do
     @bus.publish "/foo", "bar", max_backlog_age: 1
@@ -190,15 +190,15 @@ describe PUB_SUB_CLASS do
     when :postgres
       @bus.publish "/foo", "baz", max_backlog_age: 1
     # for the time being we can give pg a pass here
     # TODO: make the implementation here consistent
@@ -206,7 +206,7 @@ describe PUB_SUB_CLASS do
       # ids are not opaque we expect them to be reset on our channel if it
       # got cleared due to an expire, the reason for this is cause we will leak entries due to tracking
       # this in turn can bloat storage for the backend
-      @bus.last_id("/foo").must_equal initial_id
+      _(@bus.last_id("/foo")).must_equal initial_id
GitHub sha: 79c3f08d
This commit appears in #215 which was merged by @SamSaffron.
