FIX: Remove duplicate %-sign from error messages
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index cdfb2bf..9a86c6a 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -2073,8 +2073,8 @@ en:
       invalid_string_min_max: "Must be between %{min} and %{max} characters."
       invalid_string_min: "Must be at least %{min} characters."
       invalid_string_max: "Must be no more than %{max} characters."
-      invalid_reply_by_email_address: "Value must contain '%%{reply_key}' and be different from the notification email."
-      invalid_alternative_reply_by_email_addresses: "All values must contain '%%{reply_key}' and be different from the notification email."
+      invalid_reply_by_email_address: "Value must contain '%{reply_key}' and be different from the notification email."
+      invalid_alternative_reply_by_email_addresses: "All values must contain '%{reply_key}' and be different from the notification email."
       pop3_polling_host_is_empty: "You must set a 'pop3 polling host' before enabling POP3 polling."
       pop3_polling_username_is_empty: "You must set a 'pop3 polling username' before enabling POP3 polling."
       pop3_polling_password_is_empty: "You must set a 'pop3 polling password' before enabling POP3 polling."
GitHub sha: ce75520d
