FIX: Remove error for PostCreator in a transaction without skip_jobs (#11291)
Partial revert of b143412be473bacb50bad4c0ef8909d6a4717b67 (the refactoring is not reverted)
This broke a few things, so we need to investigate and make some changes before reinstating the error
diff --git a/lib/post_creator.rb b/lib/post_creator.rb
index d38d76e..b0f066a 100644
--- a/lib/post_creator.rb
+++ b/lib/post_creator.rb
@@ -199,12 +199,6 @@ class PostCreator
   def create
-    if !Rails.env.test? && !@opts[:import_mode]
-      if ActiveRecord::Base.connection.open_transactions > 0 && !@opts[:skip_jobs]
-        raise "You must use 'skip_jobs = true' when creating a post inside a transaction, otherwise jobs won't run properly."
-      end
-    end
     if valid?
       transaction do
         build_post_stats
GitHub sha: 0c878ef3
This commit appears in #11291 which was approved by jomaxro. It was merged by davidtaylorhq.
