FIX: Remove expired LE root cert from our local validation
The old root was getting openssl confused, resulting in a new certificate on every rebuild that could easily trigger existing let’s encrypt rate-limits.
diff --git a/templates/web.letsencrypt.ssl.template.yml b/templates/web.letsencrypt.ssl.template.yml
index fcec567..986be02 100644
--- a/templates/web.letsencrypt.ssl.template.yml
+++ b/templates/web.letsencrypt.ssl.template.yml
@@ -63,7 +63,7 @@ hooks:
         cert_exists() {
-          [[ "$(cd $$ENV_LETSENCRYPT_DIR/$$ENV_DISCOURSE_HOSTNAME$1 && openssl verify -CAfile ca.cer fullchain.cer | grep "OK")" ]]
+          [[ "$(cd $$ENV_LETSENCRYPT_DIR/$$ENV_DISCOURSE_HOSTNAME$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")" ]]
GitHub sha: 8e2ccee0f2989885632c27c7f33a87719d3838ec
This commit appears in #576 which was approved by eviltrout. It was merged by Falco.
