FIX: Remove legacy topic timer code (#13544)
The new topic timer backend code introduced six months ago in 0034cbd is now used instead of this legacy code. It can be safely removed now.
diff --git a/app/jobs/regular/topic_reminder.rb b/app/jobs/regular/topic_reminder.rb
deleted file mode 100644
index e4b103d..0000000
--- a/app/jobs/regular/topic_reminder.rb
+++ /dev/null
@@ -1,31 +0,0 @@
-# frozen_string_literal: true
-module Jobs
-  class TopicReminder < ::Jobs::Base
-    def execute(args)
-      # noop, TODO(martin 2021-03-11): Remove this after timers migrated and outstanding jobs cancelled
-      return
-      topic_timer = TopicTimer.find_by(id: args[:topic_timer_id])
-      topic = topic_timer&.topic
-      user = topic_timer&.user
-      if topic_timer.blank? || topic.blank? || user.blank? ||
-          topic_timer.execute_at > Time.zone.now
-        return
-      end
-      user.notifications.create!(
-        notification_type: Notification.types[:topic_reminder],
-        topic_id: topic.id,
-        post_number: 1,
-        data: { topic_title: topic.title, display_username: user.username }.to_json
-      topic_timer.trash!(Discourse.system_user)
-    end
-  end
-end
diff --git a/app/models/topic_timer.rb b/app/models/topic_timer.rb
index 2227004..2a9a690 100644
--- a/app/models/topic_timer.rb
+++ b/app/models/topic_timer.rb
@@ -36,10 +36,6 @@ class TopicTimer < ActiveRecord::Base
     if (will_save_change_to_execute_at? &&
        !attribute_in_database(:execute_at).nil?) ||
        will_save_change_to_user_id?
-      # TODO(martin - 2021-05-01) - Remove this backwards compatability for outstanding
-      # jobs once they have all been run and after Jobs::TopicTimerEnqueuer is in place
-      self.send("cancel_auto_#{self.class.types[status_type]}_job")
@@ -67,24 +63,9 @@ class TopicTimer < ActiveRecord::Base
   def enqueue_typed_job(time: nil)
-    return if typed_job_scheduled?
     self.send("schedule_auto_#{status_type_name}_job")
-  def typed_job_scheduled?
-    scheduled = Jobs.scheduled_for(
-      TopicTimer.type_job_map[status_type_name], topic_timer_id: id
-    ).any?
-    if [:close, :silent_close, :open].include?(status_type_name)
-      return scheduled || Jobs.scheduled_for(:toggle_topic_closed, topic_timer_id: id).any?
-    end
-    scheduled
-  end
   def self.type_job_map
       close: :close_topic,
@@ -165,48 +146,6 @@ class TopicTimer < ActiveRecord::Base
     self.status_type.to_i == TopicTimer.types[:publish_to_category]
-  # TODO(martin - 2021-05-01) - Remove cancels for toggle_topic_closed once topic timer revamp completed.
-  def cancel_auto_close_job
-    Jobs.cancel_scheduled_job(:toggle_topic_closed, topic_timer_id: id)
-    Jobs.cancel_scheduled_job(:close_topic, topic_timer_id: id)
-  end
-  def cancel_auto_open_job
-    Jobs.cancel_scheduled_job(:open_topic, topic_timer_id: id)
-  end
-  def cancel_auto_silent_close_job
-  end
-  def cancel_auto_publish_to_category_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:publish_to_category], topic_timer_id: id)
-  end
-  def cancel_auto_delete_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:delete], topic_timer_id: id)
-  end
-  def cancel_auto_reminder_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:reminder], topic_timer_id: id)
-  end
-  def cancel_auto_bump_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:bump], topic_timer_id: id)
-  end
-  def cancel_auto_delete_replies_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:delete_replies], topic_timer_id: id)
-  end
-  def cancel_auto_clear_slow_mode_job
-    Jobs.cancel_scheduled_job(TopicTimer.type_job_map[:clear_slow_mode], topic_timer_id: id)
-  end
   def schedule_auto_delete_replies_job
     Jobs.enqueue(TopicTimer.type_job_map[:delete_replies], topic_timer_id: id)
@@ -235,10 +174,6 @@ class TopicTimer < ActiveRecord::Base
     Jobs.enqueue(TopicTimer.type_job_map[:delete], topic_timer_id: id)
-  def schedule_auto_reminder_job
-  end
   def schedule_auto_clear_slow_mode_job
     Jobs.enqueue(TopicTimer.type_job_map[:clear_slow_mode], topic_timer_id: id)
diff --git a/spec/models/topic_timer_spec.rb b/spec/models/topic_timer_spec.rb
index cff5316..fde80ad 100644
--- a/spec/models/topic_timer_spec.rb
+++ b/spec/models/topic_timer_spec.rb
@@ -48,44 +48,6 @@ RSpec.describe TopicTimer, type: :model do
-    describe "#typed_job_scheduled?" do
-      let(:scheduled_jobs) { Sidekiq::ScheduledSet.new }
-      after do
-        scheduled_jobs.clear
-      end
-      it "returns true if the job is scheduled" do
-        Sidekiq::Testing.disable! do
-          Jobs.enqueue_at(3.hours.from_now, :close_topic, topic_timer_id: topic_timer.id)
-          expect(topic_timer.typed_job_scheduled?).to eq(true)
-        end
-      end
-      it "returns false if the job is not already scheduled" do
-          expect(topic_timer.typed_job_scheduled?).to eq(false)
-        end
-      end
-      it "returns true if the toggle_topic_closed job is scheduled for close,open,silent_close types" do
-          topic_timer1 = Fabricate(:topic_timer, status_type: TopicTimer.types[:close])
-          Jobs.enqueue_at(3.hours.from_now, :toggle_topic_closed, topic_timer_id: topic_timer1.id)
-          topic_timer2 = Fabricate(:topic_timer, status_type: TopicTimer.types[:open])
-          Jobs.enqueue_at(3.hours.from_now, :toggle_topic_closed, topic_timer_id: topic_timer2.id)
-          topic_timer3 = Fabricate(:topic_timer, status_type: TopicTimer.types[:silent_close])
-          Jobs.enqueue_at(3.hours.from_now, :toggle_topic_closed, topic_timer_id: topic_timer3.id)
-          expect(topic_timer1.typed_job_scheduled?).to eq(true)
-          expect(topic_timer2.typed_job_scheduled?).to eq(true)
-          expect(topic_timer3.typed_job_scheduled?).to eq(true)
-        end
-      end
-    end
     describe '#execute_at' do
       describe 'when #execute_at is greater than #created_at' do
         it 'should be valid' do
@@ -146,38 +108,11 @@ RSpec.describe TopicTimer, type: :model do
     describe 'when #execute_at and #user_id are not changed' do
       it 'should not schedule another to update topic' do
         Jobs.expects(:enqueue_at).never
-        Jobs.expects(:cancel_scheduled_job).never
         topic_timer.update!(topic: Fabricate(:topic))
-    describe 'when #execute_at value is changed' do
-      it 'reschedules the job' do
-        Jobs.expects(:cancel_scheduled_job).with(
-          :toggle_topic_closed, topic_timer_id: topic_timer.id
-          :close_topic, topic_timer_id: topic_timer.id
-        topic_timer.update!(execute_at: 3.days.from_now, created_at: Time.zone.now)
-      end
-    end
-    describe 'when user is changed' do
-      it 'should update the job' do
-        topic_timer.update!(user: admin)
GitHub sha: 03338f9086e65e8020598cd3346ed23a3d69a01e
This commit appears in #13544 which was approved by tgxworld. It was merged by martin.
