FIX: Remove List-Unsubscribe header if using group SMTP (#13448)
The other mailing list headers were removed if using group SMTP in ff6114d83f9c6203dee426968850023b77d1e031
diff --git a/app/mailers/user_notifications.rb b/app/mailers/user_notifications.rb
index a63c7b1..7f8ce6f 100644
--- a/app/mailers/user_notifications.rb
+++ b/app/mailers/user_notifications.rb
@@ -492,6 +492,7 @@ class UserNotifications < ActionMailer::Base
     from_address = nil
     delivery_method_options = nil
     use_from_address_for_reply_to = false
+    using_group_smtp = false
     template = +"user_notifications.user_#{notification_type}"
     if post.topic.private_message?
@@ -562,6 +563,7 @@ class UserNotifications < ActionMailer::Base
       # will forward the email back into Discourse and process/link it correctly.
       use_from_address_for_reply_to = true
       from_address = group.email_username
+      using_group_smtp = true
@@ -711,7 +713,8 @@ class UserNotifications < ActionMailer::Base
       locale: locale,
       delivery_method_options: delivery_method_options,
       use_from_address_for_reply_to: use_from_address_for_reply_to,
+      from: from_address,
+      add_unsubscribe_link: !using_group_smtp
     unless translation_override_exists
diff --git a/spec/components/email/sender_spec.rb b/spec/components/email/sender_spec.rb
index 27e9351..3c56e93 100644
--- a/spec/components/email/sender_spec.rb
+++ b/spec/components/email/sender_spec.rb
@@ -375,6 +375,7 @@ describe Email::Sender do
           expect(message.header['List-Post']).to eq(nil)
           expect(message.header['List-Archive']).to eq(nil)
           expect(message.header['Precedence']).to eq(nil)
+          expect(message.header['List-Unsubscribe']).to eq(nil)
GitHub sha: f0c10edd2813abc5afd7247fe2b348ec61065891
This commit appears in #13448 which was approved by techAPJ. It was merged by martin.
