FIX: remove temporary hack for fixed iOS bug (#7773)
A bug where input focus is displaced on modals was fixed in iOS 11.3 update. This hack was causing problems on topic page since hiding main-outlet results in lost read position after opening and closing a modal.
diff --git a/app/assets/javascripts/discourse/lib/show-modal.js.es6 b/app/assets/javascripts/discourse/lib/show-modal.js.es6
index 3fa2b31..f422a62 100644
--- a/app/assets/javascripts/discourse/lib/show-modal.js.es6
+++ b/app/assets/javascripts/discourse/lib/show-modal.js.es6
@@ -4,33 +4,6 @@ export default function(name, opts) {
   opts = opts || {};
   const container = Discourse.__container__;
-  // iOS 11 -> 11.1 have broken INPUTs on position fixed
-  // if for any reason there is a body higher than 100% behind them.
-  // What happens is that when INPUTs gets focus they shift the body
-  // which ends up moving the cursor to an invisible spot
-  // this makes the login experience on iOS painful, user thinks it is broken.
-  // Also, very little value in showing main outlet and header on iOS
-  // anyway, so just hide it.
-  if (isAppleDevice()) {
-    let pos = $(window).scrollTop();
-    $(window)
-      .off("show.bs.modal.ios-hacks")
-      .on("show.bs.modal.ios-hacks", () => {
-        $("#main-outlet, header").hide();
-    $(window)
-      .off("hide.bs.modal.ios-hacks")
-      .on("hide.bs.modal.ios-hacks", () => {
-        $("#main-outlet, header").show();
-        $(window).scrollTop(pos);
-        $(window).off("hide.bs.modal.ios-hacks");
-        $(window).off("show.bs.modal.ios-hacks");
   // We use the container here because modals are like singletons
   // in Discourse. Only one can be shown with a particular state.
   const route = container.lookup("route:application");
GitHub sha: 506de138
