FIX: Remove topic answer mixin from category detailed serializer.
index 3de7396..e7b9df4 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -498,7 +498,6 @@ SQL
   require_dependency 'topic_list_item_serializer'
   require_dependency 'search_topic_list_item_serializer'
   require_dependency 'suggested_topic_serializer'
-  require_dependency 'category_detailed_serializer'
   require_dependency 'user_summary_serializer'
   class ::TopicListItemSerializer
@@ -513,10 +512,6 @@ SQL
     include TopicAnswerMixin
-  class ::CategoryDetailedSerializer
-    include TopicAnswerMixin
-  end
   class ::UserSummarySerializer::TopicSerializer
GitHub sha: 818bff2b
@vinothkannans do you know why was this included in the first place and why it needed to be removed?
It’s totally a mistake. Instead of ListableTopicSerializer I added the mixin into this :man_facepalming:
