FIX: remove unsuppored rake task
rebuilding user_actions is not something that should be done.
Plugins such as solved and assigned extend it, there are tons of little rules that were not captured in user_actions:rebuild
diff --git a/lib/tasks/user_actions.rake b/lib/tasks/user_actions.rake
deleted file mode 100644
index 2d2631d..0000000
--- a/lib/tasks/user_actions.rake
+++ /dev/null
@@ -1,41 +0,0 @@
-# frozen_string_literal: true
-desc "rebuild the user_actions table"
-task "user_actions:rebuild" => :environment do
-  MessageBus.off
-  UserAction.delete_all
-  PostAction.all.each do |i|
-    if i.deleted_at.nil?
-      UserActionManager.post_action_created(i)
-    else
-      UserActionManager.post_action_destroyed(i)
-    end
-  end
-  Topic.all.each { |i| UserActionManager.log_topic(i) }
-  Post.all.each do |i|
-      UserActionManager.post_created(i)
-    else
-      UserActionManager.post_destroyed(i)
-    end
-  end
-  Notification.all.each do |notification|
-    if notification.post.deleted_at.nil?
-      UserActionManager.notification_created(
-        notification.post,
-        notification.user,
-        notification.notification_type,
-        notification.user
-    else
-      UserActionManager.notification_destroyed(
-        notification.user
-    end
-  end
-end
GitHub sha: 6b62d75c
