FIX: Replace references to flags in the header with review
diff --git a/app/assets/javascripts/discourse/components/site-header.js.es6 b/app/assets/javascripts/discourse/components/site-header.js.es6
index ac95358..a49c85f 100644
--- a/app/assets/javascripts/discourse/components/site-header.js.es6
+++ b/app/assets/javascripts/discourse/components/site-header.js.es6
@@ -7,11 +7,6 @@ import PanEvents, {
   SWIPE_VELOCITY_THRESHOLD
 } from "discourse/mixins/pan-events";
-const _flagProperties = [];
-function addFlagProperty(prop) {
-  _flagProperties.pushObject(prop);
 const PANEL_BODY_MARGIN = 30;
 //android supports pulling in from the screen edges
@@ -32,7 +27,8 @@ const SiteHeaderComponent = MountWidget.extend(Docking, PanEvents, {
   @observes(
     "currentUser.unread_notifications",
-    "currentUser.unread_private_messages"
+    "currentUser.unread_private_messages",
+    "currentUser.reviewable_count"
   notificationsChanged() {
     this.queueRerender();
@@ -274,10 +270,6 @@ const SiteHeaderComponent = MountWidget.extend(Docking, PanEvents, {
   buildArgs() {
     return {
-      flagCount: _flagProperties.reduce(
-        (prev, cur) => prev + (this.get(cur) || 0),
-        0
       topic: this._topic,
       canSignUp: this.get("canSignUp")
@@ -410,23 +402,6 @@ const SiteHeaderComponent = MountWidget.extend(Docking, PanEvents, {
 export default SiteHeaderComponent;
-function applyFlaggedProperties() {
-  const args = _flagProperties.slice();
-  args.push(
-    function() {
-      this.queueRerender();
-    }.on("init")
-  SiteHeaderComponent.reopen({
-    _flagsChanged: Ember.observer.apply(this, args)
-addFlagProperty("currentUser.reviewable_count");
-export { addFlagProperty, applyFlaggedProperties };
 export function headerHeight() {
   const $header = $("header.d-header");
   const headerOffset = $header.offset();
diff --git a/app/assets/javascripts/discourse/initializers/apply-flagged-properties.js.es6 b/app/assets/javascripts/discourse/initializers/apply-flagged-properties.js.es6
deleted file mode 100644
index 431ad56..0000000
--- a/app/assets/javascripts/discourse/initializers/apply-flagged-properties.js.es6
+++ /dev/null
@@ -1,6 +0,0 @@
-import { applyFlaggedProperties } from "discourse/components/site-header";
-export default {
-  name: "apply-flagged-properties",
-  initialize: applyFlaggedProperties
diff --git a/app/assets/javascripts/discourse/lib/plugin-api.js.es6 b/app/assets/javascripts/discourse/lib/plugin-api.js.es6
index f95769b..3bd78bc 100644
--- a/app/assets/javascripts/discourse/lib/plugin-api.js.es6
+++ b/app/assets/javascripts/discourse/lib/plugin-api.js.es6
@@ -1,3 +1,4 @@
+import deprecated from "discourse-common/lib/deprecated";
 import { iconNode } from "discourse-common/lib/icon-library";
 import { addDecorator } from "discourse/widgets/post-cooked";
 import ComposerEditor from "discourse/components/composer-editor";
@@ -15,7 +16,6 @@ import {
 } from "discourse/widgets/widget";
 import { preventCloak } from "discourse/widgets/post-stream";
 import { h } from "virtual-dom";
-import { addFlagProperty } from "discourse/components/site-header";
 import { addPopupMenuOptionsCallback } from "discourse/controllers/composer";
 import { extraConnectorClass } from "discourse/lib/plugin-connectors";
 import { addPostSmallActionIcon } from "discourse/widgets/post-small-action";
@@ -536,11 +536,10 @@ class PluginApi {
     return reopenWidget(name, args);
-   * Adds a property that can be summed for calculating the flag counter
   addFlagProperty(property) {
-    return addFlagProperty(property);
+    deprecated(
+      "addFlagProperty has been removed. Use the reviewable API instead."
diff --git a/app/assets/javascripts/discourse/widgets/header.js.es6 b/app/assets/javascripts/discourse/widgets/header.js.es6
index 1a0e7a2..271600c 100644
--- a/app/assets/javascripts/discourse/widgets/header.js.es6
+++ b/app/assets/javascripts/discourse/widgets/header.js.es6
@@ -184,18 +184,18 @@ createWidget("header-icons", {
       action: "toggleHamburger",
       href: "",
       contents() {
-        if (!attrs.flagCount) {
-          return;
+        let { currentUser } = this;
+        if (currentUser && currentUser.reviewable_count) {
+          return h(
+            "div.badge-notification.reviewables",
+              attributes: {
+                title: I18n.t("notifications.reviewable_items")
+            this.currentUser.reviewable_count
-        return h(
-          "div.badge-notification.flagged-posts",
-            attributes: {
-              title: I18n.t("notifications.total_flagged")
-          attrs.flagCount
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 7d9f5cb..67d7bdd 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -1640,7 +1640,7 @@ en:
       empty: "No notifications found."
       more: "view older notifications"
       post_approved: "Your post was approved"
-      total_flagged: "total flagged posts"
+      reviewable_items: "items requiring review"
       group_mentioned: "<span>{{username}}</span> {{description}}"
       quoted: "<span>{{username}}</span> {{description}}"
GitHub sha: 8e77b4d5
