FIX: Reset 'filter' query parameter when clicking on a nav-item (#10299)
FIX: Reset ‘filter’ query parameter when clicking on a nav-item (#10299)
Usually, this would have been implemented using resetController, but because we do not use link-to component for linking, that method is not called.
diff --git a/app/assets/javascripts/discourse/app/components/d-navigation.js b/app/assets/javascripts/discourse/app/components/d-navigation.js
index 3c4c2d4..e253003 100644
--- a/app/assets/javascripts/discourse/app/components/d-navigation.js
+++ b/app/assets/javascripts/discourse/app/components/d-navigation.js
@@ -79,6 +79,7 @@ export default Component.extend(FilterModeMixin, {
     return NavItem.buildList(category, {
       filterType,
       noSubcategories,
+      currentRouteQueryParams,
       persistedQueryParams: params,
       siteSettings: this.siteSettings
diff --git a/app/assets/javascripts/discourse/app/components/navigation-item.js b/app/assets/javascripts/discourse/app/components/navigation-item.js
index 5a3f172..ea7b41b 100644
--- a/app/assets/javascripts/discourse/app/components/navigation-item.js
+++ b/app/assets/javascripts/discourse/app/components/navigation-item.js
@@ -59,6 +59,17 @@ export default Component.extend(FilterModeMixin, {
+    // To reset the "filter" sticky param, at least one query param is needed.
+    // If no query param is present, add an empty one to ensure a ? is
+    // appended to the URL.
+    if (content.currentRouteQueryParams) {
+      if (content.currentRouteQueryParams.filter) {
+        if (queryParams.length === 0) {
+          queryParams.push("");
     if (queryParams.length) {
       href += `?${queryParams.join("&")}`;
diff --git a/app/assets/javascripts/discourse/app/models/nav-item.js b/app/assets/javascripts/discourse/app/models/nav-item.js
index beefa36..3108a9f 100644
--- a/app/assets/javascripts/discourse/app/models/nav-item.js
+++ b/app/assets/javascripts/discourse/app/models/nav-item.js
@@ -172,6 +172,9 @@ NavItem.reopenClass({
     if (opts.tagId) {
       args.tagId = opts.tagId;
+    if (opts.currentRouteQueryParams) {
+      args.currentRouteQueryParams = opts.currentRouteQueryParams;
     if (opts.persistedQueryParams) {
       args.persistedQueryParams = opts.persistedQueryParams;
diff --git a/app/assets/javascripts/discourse/app/routes/discovery.js b/app/assets/javascripts/discourse/app/routes/discovery.js
index 394c9d5..38059e2 100644
--- a/app/assets/javascripts/discourse/app/routes/discovery.js
+++ b/app/assets/javascripts/discourse/app/routes/discovery.js
@@ -8,6 +8,10 @@ import { scrollTop } from "discourse/mixins/scroll-top";
 import User from "discourse/models/user";
 export default DiscourseRoute.extend(OpenComposer, {
+  queryParams: {
+    filter: { refreshModel: true }
   redirect() {
     return this.redirectIfLoginRequired();
GitHub sha: 27d853e2
This commit appears in #10299 which was approved by eviltrout. It was merged by nbianca.
