FIX: reset gravatar cache by adding random param to URL (#9370)
Users noticed that sometimes, avatar from Gravatar is not correctly updated - Updated image on gravatar, not seeing it update on site - support - Discourse Meta
A potential reason for that is that even if you update your avatar in Gravatar, URL stays the same and if the cache is involved, service is still receiving the old photo.
For example. In my case, when I click the button to refresh avatar the new Upload record is created with origin URL to new avatar, and url to old one
I made some tests in the rails console and adding random param to Gravatar URL is deceiving cache and correct, the newest avatar is downloaded
diff --git a/app/models/user_avatar.rb b/app/models/user_avatar.rb
index c3df573..f6dbf13 100644
--- a/app/models/user_avatar.rb
+++ b/app/models/user_avatar.rb
@@ -20,7 +20,7 @@ class UserAvatar < ActiveRecord::Base
         return if user.blank? || user.primary_email.blank?
         email_hash = user_id == Discourse::SYSTEM_USER_ID ? User.email_hash("info@discourse.org") : user.email_hash
-        gravatar_url = "https://#{SiteSetting.gravatar_base_url}/avatar/#{email_hash}.png?s=#{max}&d=404"
+        gravatar_url = "https://#{SiteSetting.gravatar_base_url}/avatar/#{email_hash}.png?s=#{max}&d=404&reset_cache=#{SecureRandom.urlsafe_base64(5)}"
         # follow redirects in case gravatar change rules on us
         tempfile = FileHelper.download(
diff --git a/spec/models/user_avatar_spec.rb b/spec/models/user_avatar_spec.rb
index b4e6a54..c2434f1 100644
--- a/spec/models/user_avatar_spec.rb
+++ b/spec/models/user_avatar_spec.rb
@@ -99,10 +99,10 @@ describe UserAvatar do
     describe "404 should be silent, nothing to do really" do
       it "does nothing when avatar is 404" do
+        SecureRandom.stubs(:urlsafe_base64).returns("5555")
         freeze_time Time.now
-        stub_request(:get, "https://www.gravatar.com/avatar/#{avatar.user.email_hash}.png?d=404&s=360").
+        stub_request(:get, "https://www.gravatar.com/avatar/#{avatar.user.email_hash}.png?d=404&reset_cache=5555&s=360").
           to_return(status: 404, body: "", headers: {})
         expect do
GitHub sha: a8119760
This commit appears in #9370 which was approved by eviltrout. It was merged by lis2.
