FIX: respect nofollow exclusion setting in topic featured links. (PR #11858)
Previously, nofollow attribute is not removed even when a domain is added to the exclude_rel_nofollow_domains site setting.
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
We have to move away from Discourse.SiteSettings constant usage as it’s a global variable.
Instead could you pass in allowList as an option to this function? See this PR didn’t add this but the same approach should be done for User.currentProp - we could pass that in as an option externalLinksInNewTab: true when calling the function.
This is necessary for newer versions of Ember and to allow us to upgrade our application.
Good
Good
@vinothkannans can you try removing the Discourse.SiteSettings call this week so we can merge?
