FIX: retranspile theme JS when settings YAML changes (#7131)
diff --git a/app/models/theme_field.rb b/app/models/theme_field.rb
index d68d24b..a591a6e 100644
--- a/app/models/theme_field.rb
+++ b/app/models/theme_field.rb
@@ -220,6 +220,10 @@ class ThemeField < ActiveRecord::Base
     self.error = errors.join("\n").presence
+    if !self.error && self.target_id == Theme.targets[:settings]
+      # when settings YAML changes, we need to re-transpile theme JS and CSS
+      theme.theme_fields.where.not(id: self.id).update_all(value_baked: nil)
+    end
   def self.guess_type(name:, target:)
diff --git a/spec/models/theme_field_spec.rb b/spec/models/theme_field_spec.rb
index 067a2ff..a830990 100644
--- a/spec/models/theme_field_spec.rb
+++ b/spec/models/theme_field_spec.rb
@@ -151,6 +151,27 @@ HTML
   let(:key) { "themes.settings_errors" }
+  it "forces re-transpilation of theme JS when settings YAML changes" do
+    theme = Fabricate(:theme)
+    settings_field = ThemeField.create!(theme: theme, target_id: Theme.targets[:settings], name: "yaml", value: "setting: 5")
+    html = <<~HTML
+      <script type="text/discourse-plugin" version="0.8">
+        alert(settings.setting);
+      </script>
+    HTML
+    js_field = ThemeField.create!(theme: theme, target_id: ThemeField.types[:html], name: "header", value: html)
+    old_value_baked = js_field.value_baked
+    settings_field.update!(value: "setting: 66")
+    js_field.reload
+    expect(js_field.value_baked).to eq(nil)
+    js_field.ensure_baked!
+    expect(js_field.value_baked).to be_present
+    expect(js_field.value_baked).not_to eq(old_value_baked)
+  end
   it "generates errors for bad YAML" do
     yaml = "invalid_setting 5"
     field = create_yaml_field(yaml)
GitHub sha: 5e58cedf
