FIX: Revert Demon::DemonBase back to Demon::Base (#8132)
I introduced DemonBase because I had got some conflict between demon/base.rb and jobs/base.rb, however, to not rename base class, it is possible to use regex on absolute path in Zeitwerk custom inflector.
diff --git a/lib/demon/base.rb b/lib/demon/base.rb
new file mode 100644
index 0000000..d162611
--- /dev/null
+++ b/lib/demon/base.rb
@@ -0,0 +1,225 @@
+module Demon; end
+# intelligent fork based demonizer
+class Demon::Base
+  def self.demons
+    @demons
+  end
+  def self.start(count = 1, verbose: false)
+    @demons ||= {}
+    count.times do |i|
+      (@demons["#{prefix}_#{i}"] ||= new(i, verbose: verbose)).start
+    end
+  end
+  def self.stop
+    return unless @demons
+    @demons.values.each do |demon|
+      demon.stop
+    end
+  end
+  def self.restart
+      demon.stop
+      demon.start
+    end
+  end
+  def self.ensure_running
+      demon.ensure_running
+    end
+  end
+  attr_reader :pid, :parent_pid, :started, :index
+  attr_accessor :stop_timeout
+  def initialize(index, rails_root: nil, parent_pid: nil, verbose: false)
+    @index = index
+    @pid = nil
+    @parent_pid = parent_pid || Process.pid
+    @started = false
+    @stop_timeout = 10
+    @rails_root = rails_root || Rails.root
+    @verbose = verbose
+  end
+  def pid_file
+    "#{@rails_root}/tmp/pids/#{self.class.prefix}_#{@index}.pid"
+  end
+  def alive?(pid = nil)
+    pid ||= @pid
+    if pid
+      Demon::Base.alive?(pid)
+    else
+      false
+    end
+  end
+  def stop_signal
+    "HUP"
+  end
+  def stop
+    @started = false
+    if @pid
+      Process.kill(stop_signal, @pid)
+      wait_for_stop = lambda {
+        timeout = @stop_timeout
+        while alive? && timeout > 0
+          timeout -= (@stop_timeout / 10.0)
+          sleep(@stop_timeout / 10.0)
+          Process.waitpid(@pid, Process::WNOHANG) rescue -1
+        end
+      wait_for_stop.call
+      if alive?
+        STDERR.puts "Process would not terminate cleanly, force quitting. pid: #{@pid} #{self.class}"
+        Process.kill("KILL", @pid)
+      end
+      @pid = nil
+      @started = false
+    end
+  end
+  def ensure_running
+    return unless @started
+    if !@pid
+      @started = false
+      start
+      return
+    end
+    dead = Process.waitpid(@pid, Process::WNOHANG) rescue -1
+    if dead
+      STDERR.puts "Detected dead worker #{@pid}, restarting..."
+      @pid = nil
+      @started = false
+      start
+    end
+  end
+  def start
+    return if @pid || @started
+    if existing = already_running?
+      # should not happen ... so kill violently
+      STDERR.puts "Attempting to kill pid #{existing}"
+      Process.kill("TERM", existing)
+    end
+    @started = true
+    run
+  end
+  def run
+    if @pid = fork
+      write_pid_file
+      return
+    end
+    monitor_parent
+    establish_app
+    after_fork
+  end
+  def already_running?
+    if File.exists? pid_file
+      pid = File.read(pid_file).to_i
+      if Demon::Base.alive?(pid)
+        return pid
+      end
+    end
+    nil
+  end
+  def self.alive?(pid)
+    Process.kill(0, pid)
+    true
+  rescue
+    false
+  end
+  private
+  def verbose(msg)
+    if @verbose
+      puts msg
+    end
+  end
+  def write_pid_file
+    verbose("writing pid file #{pid_file} for #{@pid}")
+    FileUtils.mkdir_p(@rails_root + "tmp/pids")
+    File.open(pid_file, 'w') do |f|
+      f.write(@pid)
+    end
+  end
+  def delete_pid_file
+    File.delete(pid_file)
+  end
+  def monitor_parent
+    Thread.new do
+      while true
+        begin
+          unless alive?(@parent_pid)
+            Process.kill "TERM", Process.pid
+            sleep 10
+            Process.kill "KILL", Process.pid
+          end
+        rescue => e
+          STDERR.puts "URGENT monitoring thread had an exception #{e}"
+        end
+        sleep 1
+      end
+    end
+  end
+  def suppress_stdout
+    true
+  end
+  def suppress_stderr
+    true
+  end
+  def establish_app
+    Discourse.after_fork if defined?(Discourse)
+    Signal.trap("HUP") do
+      begin
+        delete_pid_file
+      ensure
+        # TERM is way cleaner than exit
+        Process.kill("TERM", Process.pid)
+      end
+    end
+    # keep stuff simple for now
+    $stdout.reopen("/dev/null", "w") if suppress_stdout
+    $stderr.reopen("/dev/null", "w") if suppress_stderr
+  end
+  def after_fork
+  end
+end
diff --git a/lib/demon/demon_base.rb b/lib/demon/demon_base.rb
deleted file mode 100644
index 8524222..0000000
--- a/lib/demon/demon_base.rb
+++ /dev/null
@@ -1,225 +0,0 @@
-# frozen_string_literal: true
-module Demon; end
-# intelligent fork based demonizer
-class Demon::DemonBase
-  def self.demons
-    @demons
-  end
-  def self.start(count = 1, verbose: false)
-    @demons ||= {}
-    count.times do |i|
-      (@demons["#{prefix}_#{i}"] ||= new(i, verbose: verbose)).start
-    end
-  end
-  def self.stop
-    return unless @demons
-    @demons.values.each do |demon|
-      demon.stop
-    end
-  end
-  def self.restart
-      demon.stop
-      demon.start
-    end
-  end
-  def self.ensure_running
-      demon.ensure_running
-    end
-  end
-  attr_reader :pid, :parent_pid, :started, :index
-  attr_accessor :stop_timeout
-  def initialize(index, rails_root: nil, parent_pid: nil, verbose: false)
-    @index = index
-    @pid = nil
-    @parent_pid = parent_pid || Process.pid
-    @started = false
-    @stop_timeout = 10
-    @rails_root = rails_root || Rails.root
-    @verbose = verbose
-  end
-  def pid_file
-    "#{@rails_root}/tmp/pids/#{self.class.prefix}_#{@index}.pid"
-  end
-  def alive?(pid = nil)
-    pid ||= @pid
-    if pid
-      Demon::DemonBase.alive?(pid)
-    else
-      false
-    end
-  end
-  def stop_signal
-    "HUP"
-  end
-  def stop
-    @started = false
-    if @pid
-      Process.kill(stop_signal, @pid)
-      wait_for_stop = lambda {
-        timeout = @stop_timeout
-        while alive? && timeout > 0
-          timeout -= (@stop_timeout / 10.0)
-          sleep(@stop_timeout / 10.0)
-          Process.waitpid(@pid, Process::WNOHANG) rescue -1
-        end
-      wait_for_stop.call
-      if alive?
-        STDERR.puts "Process would not terminate cleanly, force quitting. pid: #{@pid} #{self.class}"
-        Process.kill("KILL", @pid)
-      end
-      @pid = nil
-      @started = false
-    end
-  end
-  def ensure_running
-    return unless @started
-    if !@pid
-      @started = false
-      start
-      return
-    end
-    dead = Process.waitpid(@pid, Process::WNOHANG) rescue -1
-    if dead
-      STDERR.puts "Detected dead worker #{@pid}, restarting..."
-      @pid = nil
-      @started = false
-      start
-    end
-  end
-  def start
-    return if @pid || @started
-    if existing = already_running?
-      # should not happen ... so kill violently
-      STDERR.puts "Attempting to kill pid #{existing}"
-      Process.kill("TERM", existing)
-    end
-    @started = true
-    run
-  end
-  def run
-    if @pid = fork
-      write_pid_file
-      return
-    end
-    monitor_parent
-    establish_app
-    after_fork
-  end
-  def already_running?
-    if File.exists? pid_file
-      pid = File.read(pid_file).to_i
-      if Demon::DemonBase.alive?(pid)
-        return pid
-      end
-    end
-    nil
-  end
-  def self.alive?(pid)
-    Process.kill(0, pid)
-    true
-  rescue
-    false
-  end
-  private
-  def verbose(msg)
-    if @verbose
-      puts msg
-    end
-  end
-  def write_pid_file
-    verbose("writing pid file #{pid_file} for #{@pid}")
-    FileUtils.mkdir_p(@rails_root + "tmp/pids")
-    File.open(pid_file, 'w') do |f|
-      f.write(@pid)
-    end
-  end
-  def delete_pid_file
-    File.delete(pid_file)
GitHub sha: 35b1185a
