FIX: round the calculated heat values
Views heats like 12135 will become 12000, like ratios like 1.666666666667 will become 1.67.
diff --git a/app/services/heat_settings_updater.rb b/app/services/heat_settings_updater.rb
index 7d2ece2..56666b7 100644
--- a/app/services/heat_settings_updater.rb
+++ b/app/services/heat_settings_updater.rb
@@ -73,8 +73,19 @@ class HeatSettingsUpdater
     elsif SiteSetting.get(name) == 0 ||
       (new_value.to_f / SiteSetting.get(name) - 1.0).abs >= 0.05
-      if SiteSetting.get(name) != new_value
-        SiteSetting.set_and_log(name, new_value)
+      rounded_new_value = if new_value.is_a?(Integer)
+        if new_value > 9
+          digits = new_value.digits.reverse
+          (digits[0] * 10 + digits[1]) * 10.pow(digits[2..-1].size)
+        else
+          new_value
+        end
+      else
+        new_value.round(2)
+      end
+      if SiteSetting.get(name) != rounded_new_value
+        SiteSetting.set_and_log(name, rounded_new_value)
diff --git a/spec/services/heat_settings_updater_spec.rb b/spec/services/heat_settings_updater_spec.rb
index db32634..4f86390 100644
--- a/spec/services/heat_settings_updater_spec.rb
+++ b/spec/services/heat_settings_updater_spec.rb
@@ -75,14 +75,14 @@ describe HeatSettingsUpdater do
     context 'increased activity' do
       let!(:hottest_topic1) { Fabricate(:topic, views: 10_100, posts_count: 100, like_count: 230) }
-      let!(:hottest_topic2) { Fabricate(:topic, views: 10_000, posts_count: 100, like_count: 220) }
-      let!(:warm_topic1) { Fabricate(:topic, views: 4020, posts_count: 100, like_count: 126) }
-      let!(:warm_topic2) { Fabricate(:topic, views: 4010, posts_count: 100, like_count: 116) }
-      let!(:warm_topic3) { Fabricate(:topic, views: 4000, posts_count: 100, like_count: 106) }
-      let!(:lukewarm_topic1) { Fabricate(:topic, views: 2040, posts_count: 100, like_count: 84) }
-      let!(:lukewarm_topic2) { Fabricate(:topic, views: 2030, posts_count: 100, like_count: 74) }
-      let!(:lukewarm_topic3) { Fabricate(:topic, views: 2020, posts_count: 100, like_count: 64) }
-      let!(:lukewarm_topic4) { Fabricate(:topic, views: 2000, posts_count: 100, like_count: 54) }
+      let!(:hottest_topic2) { Fabricate(:topic, views: 10_012, posts_count: 100, like_count: 220) }
+      let!(:warm_topic1) { Fabricate(:topic, views: 4020, posts_count: 99, like_count: 126) }
+      let!(:warm_topic2) { Fabricate(:topic, views: 4010, posts_count: 99, like_count: 116) }
+      let!(:warm_topic3) { Fabricate(:topic, views: 4005, posts_count: 99, like_count: 106) }
+      let!(:lukewarm_topic1) { Fabricate(:topic, views: 2040, posts_count: 99, like_count: 84) }
+      let!(:lukewarm_topic2) { Fabricate(:topic, views: 2030, posts_count: 99, like_count: 74) }
+      let!(:lukewarm_topic3) { Fabricate(:topic, views: 2020, posts_count: 99, like_count: 64) }
+      let!(:lukewarm_topic4) { Fabricate(:topic, views: 2002, posts_count: 99, like_count: 54) }
       let!(:cold_topic) { Fabricate(:topic, views: 100, posts_count: 100, like_count: 1) }
       it 'changes settings when difference is significant' do
@@ -93,8 +93,8 @@ describe HeatSettingsUpdater do
         expect(SiteSetting.topic_views_heat_medium).to eq(4000)
         expect(SiteSetting.topic_views_heat_low).to eq(2000)
         expect(SiteSetting.topic_post_like_heat_high).to eq(2.2)
-        expect(SiteSetting.topic_post_like_heat_medium).to eq(1.06)
-        expect(SiteSetting.topic_post_like_heat_low).to eq(0.54)
+        expect(SiteSetting.topic_post_like_heat_medium).to eq(1.07)
+        expect(SiteSetting.topic_post_like_heat_low).to eq(0.55)
       it "doesn't change settings when automatic_topic_heat_values is false" do
GitHub sha: 1f73a3ba
