FIX: Ruby 3 does not freeze interpolated string (PR #14567)
This pull request addresses the failure discussed at https://meta.discourse.org/t/one-of-topicembed-import-spec-fails-with-ruby-3/205358/2
Background
Ruby 2.7 or earlier +contents returns self.dup when frozen_string_literal: true. However, Ruby 3.0 returns self because this string is interpolated one, which is not frozen anymore. This commit uses self.dup to return duplicated string regardless Ruby versions.
Refer Feature #17104: Do not freeze interpolated strings when using frozen-string-literal - Ruby master - Ruby Issue Tracking System
Steps to reproduce
$ bundle exec rspec ./spec/models/topic_embed_spec.rb:154
Expected behavior
It should pass as Ruby 2.7 does.
Expected behavior
It always fails as follows with Ruby 3.0.2
$ ruby -v
ruby 3.0.2p107 (2021-07-07 revision 0db68f0233) [x86_64-linux]
Run options: include {:locations=>{"./spec/models/topic_embed_spec.rb"=>[154]}}
Randomized with seed 61369
F
Failures:
  1) TopicEmbed.import embedded content truncation keeps everything in the imported post when truncation is disabled
     Failure/Error: expect(post.raw).to include(long_content)
       expected "<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa...for the original entry at <a href=\"http://eviltrout.com/123\">http://eviltrout.com/123</a></small>" to include "<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa...for the original entry at <a href='http://eviltrout.com/123'>http://eviltrout.com/123</a></small>\n"
       Diff:
       @@ -1,4 +1,7 @@
       -<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa</p>\n<p>more</p>\n<hr>\n<small>This is a companion discussion topic for the original entry at <a href='http://eviltrout.com/123'>http://eviltrout.com/123</a></small>\n
       +<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa</p>
       +<p>more</p>
       +<hr>
       +<small>This is a companion discussion topic for the original entry at <a href="http://eviltrout.com/123">http://eviltrout.com/123</a></small>
     # ./spec/models/topic_embed_spec.rb:158:in `block (4 levels) in <top (required)>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
Finished in 2.46 seconds (files took 2.4 seconds to load)
1 example, 1 failure
Failed examples:
rspec ./spec/models/topic_embed_spec.rb:154 # TopicEmbed.import embedded content truncation keeps everything in the imported post when truncation is disabled
GitHub
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
The .dup is right, we should not be changing the value of the caller here.
