FIX: saving drafts unconditionally increases sequence
Previously we only changed sequence on ownership change, this cause a race condition between tabs where user could type for a long time without being warned of an out of date draft.
This change is a radical change and we should watch closely.
Code was already in place to track sequence on the client so no changes are needed there.
diff --git a/app/models/draft.rb b/app/models/draft.rb
index 9d4c08e..a2fba62 100644
--- a/app/models/draft.rb
+++ b/app/models/draft.rb
@@ -43,17 +43,17 @@ class Draft < ActiveRecord::Base
         raise Draft::OutOfSequence
-      if owner && current_owner && current_owner != owner
-        sequence += 1
-        DraftSequence.upsert({
-            sequence: sequence,
-            draft_key: key,
-            user_id: user.id,
-          unique_by: [:user_id, :draft_key]
-      end
+      sequence += 1
+      # we need to keep upping our sequence on every save
+      # if we do not do that there are bad race conditions
+      DraftSequence.upsert({
+          sequence: sequence,
+          draft_key: key,
+          user_id: user.id,
+        unique_by: [:user_id, :draft_key]
       DB.exec(<<~SQL, id: draft_id, sequence: sequence, data: data, owner: owner || current_owner)
         UPDATE drafts
@@ -337,7 +337,7 @@ end
 #  data       :text             not null
 #  created_at :datetime         not null
 #  updated_at :datetime         not null
-#  sequence   :integer          default(0), not null
+#  sequence   :bigint           default(0), not null
 #  revisions  :integer          default(1), not null
 #  owner      :string
diff --git a/app/models/draft_sequence.rb b/app/models/draft_sequence.rb
index ecdfff4..411d774 100644
--- a/app/models/draft_sequence.rb
+++ b/app/models/draft_sequence.rb
@@ -48,7 +48,7 @@ end
 #  id        :integer          not null, primary key
 #  user_id   :integer          not null
 #  draft_key :string           not null
-#  sequence  :integer          not null
+#  sequence  :bigint           not null
 # Indexes
diff --git a/db/migrate/20200512064023_change_draft_sequence_to_bigint.rb b/db/migrate/20200512064023_change_draft_sequence_to_bigint.rb
new file mode 100644
index 0000000..97d511e
--- /dev/null
+++ b/db/migrate/20200512064023_change_draft_sequence_to_bigint.rb
@@ -0,0 +1,8 @@
+class ChangeDraftSequenceToBigint < ActiveRecord::Migration[6.0]
+  def change
+    change_column :drafts, :sequence, :bigint, default: 0, null: false
+    change_column :draft_sequences, :sequence, :bigint, null: false
+  end
+end
diff --git a/spec/models/draft_spec.rb b/spec/models/draft_spec.rb
index 823ab5f..b2066b0 100644
--- a/spec/models/draft_spec.rb
+++ b/spec/models/draft_spec.rb
@@ -21,13 +21,13 @@ describe Draft do
         random_key: "random"
-      Draft.set(user, "xyz", 0, draft.to_json)
+      seq = Draft.set(user, "xyz", 0, draft.to_json)
       draft["reply"] = "test" * 100
       half_grace = (SiteSetting.editing_grace_period / 2 + 1).seconds
       freeze_time half_grace.from_now
+      seq = Draft.set(user, "xyz", seq, draft.to_json)
       draft_post = BackupDraftPost.find_by(user_id: user.id, key: "xyz").post
@@ -37,7 +37,7 @@ describe Draft do
       # this should trigger a post revision as 10 minutes have passed
       draft["reply"] = "hello"
+      Draft.set(user, "xyz", seq, draft.to_json)
       draft_topic = BackupDraftTopic.find_by(user_id: user.id)
       expect(draft_topic.topic.posts_count).to eq(2)
@@ -58,9 +58,16 @@ describe Draft do
   it "should overwrite draft data correctly" do
-    Draft.set(user, "test", 0, "data")
-    Draft.set(user, "test", 0, "new data")
-    expect(Draft.get(user, "test", 0)).to eq "new data"
+    seq = Draft.set(user, "test", 0, "data")
+    seq = Draft.set(user, "test", seq, "new data")
+    expect(Draft.get(user, "test", seq)).to eq "new data"
+  end
+  it "should increase the sequence on every save" do
+    expect(seq).to eq(0)
+    expect(seq).to eq(1)
   it "should clear drafts on request" do
@@ -227,7 +234,7 @@ describe Draft do
       expect(draft_seq).to eq(1)
       draft_seq = Draft.set(user, 'new_topic', 1, 'hello world', _owner = 'HIJKL')
-      expect(draft_seq).to eq(1)
+      expect(draft_seq).to eq(2)
     it 'can correctly preload drafts' do
diff --git a/spec/requests/draft_controller_spec.rb b/spec/requests/draft_controller_spec.rb
index f0596ce..f828e6d 100644
--- a/spec/requests/draft_controller_spec.rb
+++ b/spec/requests/draft_controller_spec.rb
@@ -22,7 +22,7 @@ describe DraftController do
   it "returns 404 when the key is missing" do
-    user = sign_in(Fabricate(:user))
+    _user = sign_in(Fabricate(:user))
     post "/draft.json", params: { data: { my: "data" }.to_json, sequence: 0 }
     expect(response.status).to eq(404)
@@ -135,18 +135,18 @@ describe DraftController do
     expect(response.status).to eq(200)
     json = response.parsed_body
-    expect(json["draft_sequence"]).to eq(1)
+    expect(json["draft_sequence"]).to eq(2)
       draft_key: "abc",
-      sequence: 1,
+      sequence: 2,
       data: { c: "test" }.to_json,
       owner: "abc"
-    expect(json["draft_sequence"]).to eq(2)
+    expect(json["draft_sequence"]).to eq(3)
   it 'raises an error for out-of-sequence draft setting' do
GitHub sha: a29ae17d
