FIX: Search by relevance may return incorrect post number.
Follow up to d8c796bc4.
Note that his change increases query time by around 40% in the following benchmark against dev.discourse.org but this is a tradeoff that has to be taken so that relevance search is accurate.
require 'benchmark/ips'
Benchmark.ips do |x|
  x.config(time: 10, warmup: 2)
  x.report("current aggregate search query") do
    DB.exec <<~SQL
    SELECT "posts"."id", "posts"."user_id", "posts"."topic_id", "posts"."post_number", "posts"."raw", "posts"."cooked", "posts"."created_at", "posts"."updated_at", "posts"."reply_to_post_number", "posts"."reply_count", "posts"."quote_count", "posts"."deleted_at", "posts"."off_topic_count", "posts"."like_count", "posts"."incoming_link_count", "posts"."bookmark_count", "posts"."score", "posts"."reads", "posts"."post_type", "posts"."sort_order", "posts"."last_editor_id", "posts"."hidden", "posts"."hidden_reason_id", "posts"."notify_moderators_count", "posts"."spam_count", "posts"."illegal_count", "posts"."inappropriate_count", "posts"."last_version_at", "posts"."user_deleted", "posts"."reply_to_user_id", "posts"."percent_rank", "posts"."notify_user_count", "posts"."like_score", "posts"."deleted_by_id", "posts"."edit_reason", "posts"."word_count", "posts"."version", "posts"."cook_method", "posts"."wiki", "posts"."baked_at", "posts"."baked_version", "posts"."hidden_at", "posts"."self_edits", "posts"."reply_quoted", "posts"."via_email", "posts"."raw_email", "posts"."public_version", "posts"."action_code", "posts"."locked_by_id", "posts"."image_upload_id" FROM "posts" JOIN (SELECT *, row_number() over() row_number FROM (SELECT topics.id, min(posts.post_number) post_number FROM "posts" INNER JOIN "post_search_data" ON "post_search_data"."post_id" = "posts"."id" INNER JOIN "topics" ON "topics"."id" = "posts"."topic_id" AND ("topics"."deleted_at" IS NULL) LEFT JOIN categories ON categories.id = topics.category_id WHERE ("posts"."deleted_at" IS NULL) AND "posts"."post_type" IN (1, 2, 3, 4) AND (topics.visible) AND (topics.archetype <> 'private_message') AND (post_search_data.search_data @@ TO_TSQUERY('english', '''postgres'':*ABCD')) AND (categories.id NOT IN (
      SELECT categories.id WHERE categories.search_priority = 1
    ) AND ((categories.id IS NULL) OR (NOT categories.read_restricted)) GROUP BY topics.id ORDER BY MAX((
      TS_RANK_CD(
        post_search_data.search_data,
        TO_TSQUERY('english', '''postgres'':*ABCD'),
        1|32
        CASE categories.search_priority
        WHEN 2
        THEN 0.6
        WHEN 3
        THEN 0.8
        WHEN 4
        THEN 1.2
        WHEN 5
        THEN 1.4
        ELSE
          CASE WHEN topics.closed
          THEN 0.9
          ELSE 1
          END
        END
    ) DESC, topics.bumped_at DESC LIMIT 51 OFFSET 0) xxx) x ON x.id = posts.topic_id AND x.post_number = posts.post_number WHERE ("posts"."deleted_at" IS NULL) ORDER BY row_number;
    SQL
  x.report("current aggregate search query with proper ranking") do
    DB.exec <<~SQL
    SELECT "posts"."id", "posts"."user_id", "posts"."topic_id", "posts"."post_number", "posts"."raw", "posts"."cooked", "posts"."created_at", "posts"."updated_at", "posts"."reply_to_post_number", "posts"."reply_count", "posts"."quote_count", "posts"."deleted_at", "posts"."off_topic_count", "posts"."like_count", "posts"."incoming_link_count", "posts"."bookmark_count", "posts"."score", "posts"."reads", "posts"."post_type", "posts"."sort_order", "posts"."last_editor_id", "posts"."hidden", "posts"."hidden_reason_id", "posts"."notify_moderators_count", "posts"."spam_count", "posts"."illegal_count", "posts"."inappropriate_count", "posts"."last_version_at", "posts"."user_deleted", "posts"."reply_to_user_id", "posts"."percent_rank", "posts"."notify_user_count", "posts"."like_score", "posts"."deleted_by_id", "posts"."edit_reason", "posts"."word_count", "posts"."version", "posts"."cook_method", "posts"."wiki", "posts"."baked_at", "posts"."baked_version", "posts"."hidden_at", "posts"."self_edits", "posts"."reply_quoted", "posts"."via_email", "posts"."raw_email", "posts"."public_version", "posts"."action_code", "posts"."locked_by_id", "posts"."image_upload_id" FROM "posts" JOIN (SELECT *, row_number() over() row_number FROM (SELECT subquery.topic_id id, (ARRAY_AGG(subquery.post_number ORDER BY rank DESC, bumped_at DESC))[1] post_number, MAX(subquery.rank) rank, MAX(subquery.bumped_at) bumped_at FROM (SELECT "posts"."id", "posts"."user_id", "posts"."topic_id", "posts"."post_number", "posts"."raw", "posts"."cooked", "posts"."created_at", "posts"."updated_at", "posts"."reply_to_post_number", "posts"."reply_count", "posts"."quote_count", "posts"."deleted_at", "posts"."off_topic_count", "posts"."like_count", "posts"."incoming_link_count", "posts"."bookmark_count", "posts"."score", "posts"."reads", "posts"."post_type", "posts"."sort_order", "posts"."last_editor_id", "posts"."hidden", "posts"."hidden_reason_id", "posts"."notify_moderators_count", "posts"."spam_count", "posts"."illegal_count", "posts"."inappropriate_count", "posts"."last_version_at", "posts"."user_deleted", "posts"."reply_to_user_id", "posts"."percent_rank", "posts"."notify_user_count", "posts"."like_score", "posts"."deleted_by_id", "posts"."edit_reason", "posts"."word_count", "posts"."version", "posts"."cook_method", "posts"."wiki", "posts"."baked_at", "posts"."baked_version", "posts"."hidden_at", "posts"."self_edits", "posts"."reply_quoted", "posts"."via_email", "posts"."raw_email", "posts"."public_version", "posts"."action_code", "posts"."locked_by_id", "posts"."image_upload_id", (
      TS_RANK_CD(
        1|32
        WHEN 2
        THEN 0.6
        WHEN 3
        THEN 0.8
        WHEN 4
        THEN 1.2
        WHEN 5
        THEN 1.4
        ELSE
          THEN 0.9
          ELSE 1
          END
        END
     rank, topics.bumped_at bumped_at FROM "posts" INNER JOIN "post_search_data" ON "post_search_data"."post_id" = "posts"."id" INNER JOIN "topics" ON "topics"."id" = "posts"."topic_id" AND ("topics"."deleted_at" IS NULL) LEFT JOIN categories ON categories.id = topics.category_id WHERE ("posts"."deleted_at" IS NULL) AND "posts"."post_type" IN (1, 2, 3, 4) AND (topics.visible) AND (topics.archetype <> 'private_message') AND (post_search_data.search_data @@ TO_TSQUERY('english', '''postgres'':*ABCD')) AND (categories.id NOT IN (
    ) AND ((categories.id IS NULL) OR (NOT categories.read_restricted))) subquery GROUP BY subquery.topic_id ORDER BY rank DESC, bumped_at DESC LIMIT 51 OFFSET 0) xxx) x ON x.id = posts.topic_id AND x.post_number = posts.post_number WHERE ("posts"."deleted_at" IS NULL) ORDER BY row_number;
    SQL
  x.compare!
Warming up --------------------------------------
                         1.000  i/100ms
                         1.000  i/100ms
Calculating -------------------------------------
                         18.040  (± 0.0%) i/s -    181.000  in  10.035241s
                         12.992  (± 0.0%) i/s -    130.000  in  10.007214s
Comparison:
current aggregate search query:       18.0 i/s
current aggregate search query with proper ranking:       13.0 i/s - 1.39x  (± 0.00) slower
diff --git a/lib/search.rb b/lib/search.rb
index 040f149..34893db 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -896,10 +896,7 @@ class Search
     if aggregate_search
       aggregate_relation = Post.unscoped
-        .select(
-          "subquery.topic_id id",
-          "(ARRAY_AGG(subquery.post_number))[1] post_number",
+        .select("subquery.topic_id id")
         .group("subquery.topic_id")
       posts = posts.select(posts.arel.projections)
@@ -910,7 +907,10 @@ class Search
       if aggregate_search
         aggregate_relation = aggregate_relation
-          .select("MAX(subquery.created_at) created_at")
+          .select(
+            "(ARRAY_AGG(subquery.post_number ORDER BY subquery.created_at DESC))[1] post_number",
+            "MAX(subquery.created_at) created_at"
           .order("created_at DESC")
     elsif @order == :latest_topic
@@ -920,7 +920,10 @@ class Search
         posts = posts.select("topics.created_at topic_created_at")
-          .select("MAX(subquery.topic_created_at) topic_created_at")
+          .select(
+            "(ARRAY_AGG(subquery.post_number ORDER BY subquery.topic_created_at DESC))[1] post_number",
+            "MAX(subquery.topic_created_at) topic_created_at"
           .order("topic_created_at DESC")
     elsif @order == :views
@@ -930,7 +933,10 @@ class Search
         posts = posts.select("topics.views topic_views")
-          .select("MAX(subquery.topic_views) topic_views")
+          .select(
+            "(ARRAY_AGG(subquery.post_number ORDER BY subquery.topic_views DESC))[1] post_number",
+            "MAX(subquery.topic_views) topic_views"
           .order("topic_views DESC")
     elsif @order == :likes
@@ -976,7 +982,10 @@ class Search
           .order("rank DESC", "topic_bumped_at DESC")
-          .select("MAX(subquery.rank) rank", "MAX(subquery.topic_bumped_at) topic_bumped_at")
+          .select(
+            "(ARRAY_AGG(subquery.post_number ORDER BY subquery.rank DESC, subquery.topic_bumped_at DESC))[1] post_number",
+            "MAX(subquery.rank) rank", "MAX(subquery.topic_bumped_at) topic_bumped_at"
       else
         posts = posts.order("#{data_ranking} DESC", "topics.bumped_at DESC")
diff --git a/spec/components/search_spec.rb b/spec/components/search_spec.rb
index 075043d..4f3fd88 100644
--- a/spec/components/search_spec.rb
+++ b/spec/components/search_spec.rb
@@ -447,9 +447,13 @@ describe Search do
     it 'aggregates searches in a topic by returning the post with the highest rank' do
       post = Fabricate(:post, topic: topic, raw: "this is a play post")
-      post2 = Fabricate(:post, topic: topic, raw: "play playing played")
+      post2 = Fabricate(:post, topic: topic, raw: "play play playing played play")
       post3 = Fabricate(:post, raw: "this is a play post")
+      5.times do
+        Fabricate(:post, topic: topic, raw: "play playing played")
+      end
       results = Search.execute('play')
       expect(results.posts.map(&:id)).to eq([
GitHub sha: 5bf0a089
