FIX: second factor cannot be enabled if SSO is enabled (#10880)
  • FIX: second factor cannot be enabled if SSO is enabled
If enable_sso setting is enabled then admin should not be able to enable enforce_second_factor setting as that will lock users out.
Co-authored-by: Robin Ward robin.ward@gmail.com
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 6d0ccad..1cbf744 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -196,6 +196,7 @@ en:
       share_quote_facebook_requirements: "You must set a Facebook app id to enable quote sharing for Facebook."
       second_factor_cannot_enforce_with_socials: "You cannot enforce 2FA with social logins enabled. You must first disable login via: %{auth_provider_names}"
       second_factor_cannot_be_enforced_with_disabled_local_login: "You cannot enforce 2FA if local logins are disabled."
+      second_factor_cannot_be_enforced_with_sso_enabled: "You cannot enforce 2FA if SSO is enabled."
       local_login_cannot_be_disabled_if_second_factor_enforced: "You cannot disable local login if 2FA is enforced. Disable enforced 2FA before disabling local logins."
       cannot_enable_s3_uploads_when_s3_enabled_globally: "You cannot enable S3 uploads because S3 uploads are already globally enabled, and enabling this site-level could cause critical issues with uploads"
     conflicting_google_user_id: 'The Google Account ID for this account has changed; staff intervention is required for security reasons. Please contact staff and point them to <br><a href="https://meta.discourse.org/t/76575">https://meta.discourse.org/t/76575</a>'
diff --git a/lib/site_settings/validations.rb b/lib/site_settings/validations.rb
index c49b839..6a1f995 100644
--- a/lib/site_settings/validations.rb
+++ b/lib/site_settings/validations.rb
@@ -173,6 +173,9 @@ module SiteSettings::Validations
   def validate_enforce_second_factor(new_val)
+    if SiteSetting.enable_sso?
+      return validate_error :second_factor_cannot_be_enforced_with_sso_enabled
+    end
     if new_val == "all" && Discourse.enabled_auth_providers.count > 0
       auth_provider_names = Discourse.enabled_auth_providers.map(&:name).join(", ")
       return validate_error(:second_factor_cannot_enforce_with_socials, auth_provider_names: auth_provider_names)
diff --git a/spec/lib/site_settings/validations_spec.rb b/spec/lib/site_settings/validations_spec.rb
index 420e8f4..63aeaa1 100644
--- a/spec/lib/site_settings/validations_spec.rb
+++ b/spec/lib/site_settings/validations_spec.rb
@@ -149,6 +149,18 @@ describe SiteSettings::Validations do
           expect { subject.validate_enforce_second_factor("all") }.to raise_error(Discourse::InvalidParameters, error_message)
+      context "when SSO is enabled" do
+        let(:error_message) { I18n.t("errors.site_settings.second_factor_cannot_be_enforced_with_sso_enabled") }
+        before do
+          SiteSetting.sso_url = "https://www.example.com/sso"
+          SiteSetting.enable_sso = true
+        end
+        it "should raise an error" do
+          expect { subject.validate_enforce_second_factor("t") }.to raise_error(Discourse::InvalidParameters, error_message)
+        end
+      end
     describe "#validate_enable_local_logins" do
GitHub sha: 4326827a
This commit appears in #10880 which was approved by eviltrout. It was merged by techAPJ.
