FIX: second factor cannot be enabled if SSO is enabled (PR #10880)
If enable_sso setting is enabled then admin should not be able to enable enforce_second_factor setting as that will lock users out.
GitHub
    if SiteSetting.enable_sso?
Any particular reason why you were checking if == true?
No particular reason. It was an oversight on my part.
