FIX: Sensitivity did not work by default
Forums without previously calculated scores would return the same values for low/medium/high sensitivity. Now those are scaled based on the default value.
The default value has also been changed from 10.0 to 12.5 based on observing data from live discourse forums.
diff --git a/app/models/reviewable.rb b/app/models/reviewable.rb
index dd7be14..6fa2ecc 100644
--- a/app/models/reviewable.rb
+++ b/app/models/reviewable.rb
@@ -78,6 +78,12 @@ class Reviewable < ActiveRecord::Base
+  # This number comes from looking at forums in the wild and what numbers work.
+  # As the site accumulates real data it'll be based on the site activity instead.
+  def self.typical_sensitivity
+    12.5
+  end
   # Generate `pending?`, `rejected?`, etc helper methods
   statuses.each do |name, id|
     define_method("#{name}?") { status == id }
@@ -195,11 +201,13 @@ class Reviewable < ActiveRecord::Base
     return Float::MAX if sensitivity == 0
     ratio = sensitivity / Reviewable.sensitivity[:low].to_f
-    high = PluginStore.get('reviewables', "priority_#{Reviewable.priorities[:high]}")
-    return (10.0 * scale) if high.nil?
+    high = (
+      PluginStore.get('reviewables', "priority_#{Reviewable.priorities[:high]}") ||
+      typical_sensitivity
+    ).to_f
     # We want this to be hard to reach
-    (high.to_f * ratio) * scale
+    ((high.to_f * ratio) * scale).truncate(2)
   def self.sensitivity_score(sensitivity, scale: 1.0)
diff --git a/lib/post_action_creator.rb b/lib/post_action_creator.rb
index eacf1d3..fa2b87a 100644
--- a/lib/post_action_creator.rb
+++ b/lib/post_action_creator.rb
@@ -155,6 +155,7 @@ private
   def auto_hide_if_needed
     return if @post.hidden?
     return if !@created_by.staff? && @post.user&.staff?
+    return unless PostActionType.auto_action_flag_types.include?(@post_action_name)
     # Special case: If you have TL3 and the user is TL0, and the flag is spam,
     # hide it immediately.
@@ -163,11 +164,11 @@ private
         @post.user&.trust_level == TrustLevel[0]
       @post.hide!(@post_action_type_id, Post.hidden_reasons[:flagged_by_tl3_user])
       return
-    elsif PostActionType.auto_action_flag_types.include?(@post_action_name)
-      score = ReviewableFlaggedPost.find_by(target: @post)&.score || 0
-      if score >= Reviewable.score_required_to_hide_post
-        @post.hide!(@post_action_type_id)
-      end
+    end
+    score = ReviewableFlaggedPost.find_by(target: @post)&.score || 0
+    if score >= Reviewable.score_required_to_hide_post
+      @post.hide!(@post_action_type_id)
diff --git a/spec/models/reviewable_spec.rb b/spec/models/reviewable_spec.rb
index 08d36bf..6e8cfa3 100644
--- a/spec/models/reviewable_spec.rb
+++ b/spec/models/reviewable_spec.rb
@@ -339,11 +339,13 @@ RSpec.describe Reviewable, type: :model do
       expect(Reviewable.score_required_to_hide_post).to eq(40.0)
-    it "returns 10 if we can't calculated any percentiles" do
+    it "returns a default if we can't calculated any percentiles" do
       SiteSetting.hide_post_sensitivity = Reviewable.sensitivity[:low]
-      expect(Reviewable.score_required_to_hide_post).to eq(10.0)
+      expect(Reviewable.score_required_to_hide_post).to eq(12.5)
       SiteSetting.hide_post_sensitivity = Reviewable.sensitivity[:medium]
+      expect(Reviewable.score_required_to_hide_post).to eq(8.33)
+      SiteSetting.hide_post_sensitivity = Reviewable.sensitivity[:high]
+      expect(Reviewable.score_required_to_hide_post).to eq(4.16)
     it "returns a fraction of the high percentile" do
@@ -360,37 +362,37 @@ RSpec.describe Reviewable, type: :model do
   context ".spam_score_to_silence_new_user" do
-    it "returns 6 if we can't calculated any percentiles" do
+    it "returns a default value if we can't calculated any percentiles" do
       SiteSetting.silence_new_user_sensitivity = Reviewable.sensitivity[:low]
-      expect(Reviewable.spam_score_to_silence_new_user).to eq(6.0)
+      expect(Reviewable.spam_score_to_silence_new_user).to eq(7.5)
       SiteSetting.silence_new_user_sensitivity = Reviewable.sensitivity[:medium]
+      expect(Reviewable.spam_score_to_silence_new_user).to eq(4.99)
       SiteSetting.silence_new_user_sensitivity = Reviewable.sensitivity[:high]
+      expect(Reviewable.spam_score_to_silence_new_user).to eq(2.49)
       Reviewable.set_priorities(high: 100.0)
       SiteSetting.silence_new_user_sensitivity = Reviewable.sensitivity[:disabled]
-      expect(Reviewable.spam_score_to_silence_new_user.to_f.truncate(2)).to eq(Float::MAX)
+      expect(Reviewable.spam_score_to_silence_new_user.to_f).to eq(Float::MAX)
-      expect(Reviewable.spam_score_to_silence_new_user.to_f.truncate(2)).to eq(60.0)
+      expect(Reviewable.spam_score_to_silence_new_user.to_f).to eq(60.0)
-      expect(Reviewable.spam_score_to_silence_new_user.to_f.truncate(2)).to eq(39.99)
+      expect(Reviewable.spam_score_to_silence_new_user.to_f).to eq(39.99)
-      expect(Reviewable.spam_score_to_silence_new_user.to_f.truncate(2)).to eq(19.99)
+      expect(Reviewable.spam_score_to_silence_new_user.to_f).to eq(19.99)
   context ".score_to_auto_close_topic" do
-    it "returns 25 if we can't calculated any percentiles" do
+    it "returns the default if we can't calculated any percentiles" do
       SiteSetting.auto_close_topic_sensitivity = Reviewable.sensitivity[:low]
-      expect(Reviewable.score_to_auto_close_topic).to eq(25.0)
+      expect(Reviewable.score_to_auto_close_topic).to eq(31.25)
       SiteSetting.auto_close_topic_sensitivity = Reviewable.sensitivity[:medium]
+      expect(Reviewable.score_to_auto_close_topic).to eq(20.83)
       SiteSetting.auto_close_topic_sensitivity = Reviewable.sensitivity[:high]
+      expect(Reviewable.score_to_auto_close_topic).to eq(10.41)
GitHub sha: 3c6a5836
