FIX: Set category description to first posts cooked value (PR #9478)
We do not notice this bug right now, because the default category description has no markdown that needs to be converted into html.
Once the category definition topic/post are created, simply set the description of the category to the posts cooked value.
GitHub
Could you please create a test?
@eviltrout Alright, the specs were actually failing. Category descriotion does not get set to the first post’s cooked value if the description was actually blank.
I added a check to keep the categories description unset if no description is passed into the Category.
