FIX: Show holiday name only once (#120)
index 09fb275..8b5e41b 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -422,9 +422,9 @@ after_initialize do
     grouped.each do |_, v|
-      v[:name] = v[:name].sort.join(", ")
-      v[:usernames].sort!
-      v[:usernames].uniq!
+      v[:name].sort!.uniq!
+      v[:name] = v[:name].join(", ")
+      v[:usernames].sort!.uniq!
     standalones + grouped.values
diff --git a/spec/serializers/post_serializer_spec.rb b/spec/serializers/post_serializer_spec.rb
index 2339527..69d31a6 100644
--- a/spec/serializers/post_serializer_spec.rb
+++ b/spec/serializers/post_serializer_spec.rb
@@ -32,6 +32,9 @@ describe PostSerializer do
     user = Fabricate(:user)
     user.upsert_custom_fields(::DiscourseCalendar::REGION_CUSTOM_FIELD => 'ar')
+    user2 = Fabricate(:user)
+    user2.upsert_custom_fields(::DiscourseCalendar::REGION_CUSTOM_FIELD => 'ar')
     post = create_post(raw: "[calendar]\n[/calendar]")
     SiteSetting.holiday_calendar_topic_id = post.topic.id
@@ -45,6 +48,6 @@ describe PostSerializer do
       "Feriado puente turístico",
       "Día de la Independencia"
-    expect(json[:post][:calendar_details].map { |x| x[:usernames] }).to all (contain_exactly(user.username))
+    expect(json[:post][:calendar_details].map { |x| x[:usernames] }).to all (contain_exactly(user.username, user2.username))
GitHub sha: 776e3d1b
This commit appears in #120 which was approved by eviltrout. It was merged by udan11.
