FIX: Show tag count for existing tags (#9892)
  • FIX: Show tag count for existing tags
  • Add test
diff --git a/app/assets/javascripts/select-kit/addon/components/mini-tag-chooser.js b/app/assets/javascripts/select-kit/addon/components/mini-tag-chooser.js
index 5c7035a..4ec0997 100644
--- a/app/assets/javascripts/select-kit/addon/components/mini-tag-chooser.js
+++ b/app/assets/javascripts/select-kit/addon/components/mini-tag-chooser.js
@@ -45,7 +45,7 @@ export default ComboBox.extend(TagsMixin, {
   modifyComponentForRow(collection, item) {
-    if (this.getValue(item) === this.selectKit.filter) {
+    if (this.getValue(item) === this.selectKit.filter && !item.count) {
       return "select-kit/select-kit-row";
diff --git a/test/javascripts/components/select-kit/mini-tag-chooser-test.js b/test/javascripts/components/select-kit/mini-tag-chooser-test.js
index 76265e7..c17b01b 100644
--- a/test/javascripts/components/select-kit/mini-tag-chooser-test.js
+++ b/test/javascripts/components/select-kit/mini-tag-chooser-test.js
@@ -31,7 +31,20 @@ componentTest("create a tag", {
     assert.equal(this.subject.header().value(), "foo,bar");
     await this.subject.expand();
-    await this.subject.fillInFilter("monkey");
+    await this.subject.fillInFilter("mon");
+    assert.equal(
+      find(".select-kit-row")
+        .text()
+        .trim(),
+      "monkey x1"
+    await this.subject.fillInFilter("key");
+    assert.equal(
+        .text()
+        .trim(),
+      "monkey x1"
     await this.subject.keyboard("enter");
     assert.equal(this.subject.header().value(), "foo,bar,monkey");
GitHub sha: dd85d44d
This commit appears in #9892 which was approved by ZogStriP. It was merged by nbianca.
