FIX: show unassign button on mobile
From 1f938c3f416306438c8d90028c6cd8cc93477479 Mon Sep 17 00:00:00 2001
Date: Fri, 23 Nov 2018 09:57:13 +1100
Subject: [PATCH] FIX: show unassign button on mobile
diff --git a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6 b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
index 486ac0e..e7de592 100644
--- a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
+++ b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
@@ -1,5 +1,6 @@
 import { withPluginApi } from "discourse/lib/plugin-api";
 import { default as computed } from "ember-addons/ember-computed-decorators";
+import { ajax } from "discourse/lib/ajax";
 // should this be in API ?
 import showModal from "discourse/lib/show-modal";
@@ -12,11 +13,19 @@ function modifySelectKit(api) {
     .modifySelectKit("topic-footer-mobile-dropdown")
     .modifyContent((context, existingContent) => {
       if (context.get("currentUser.staff")) {
-        existingContent.push({
-          id: "assign",
-          icon: "user-plus",
-          name: I18n.t("discourse_assign.assign.title")
+        if (context.get("topic.assigned_to_user")) {
+          existingContent.push({
+            id: "unassign",
+            icon: "user-times",
+            name: I18n.t("discourse_assign.unassign.title")
+        } else {
+            id: "assign",
+            icon: "user-plus",
+            name: I18n.t("discourse_assign.assign.title")
       return existingContent;
@@ -35,11 +44,18 @@ function modifySelectKit(api) {
         context.set("value", null);
+      } else if (value === "unassign") {
+        topic.set("assigned_to_user", null);
+        ajax("/assign/unassign", {
+          type: "PUT",
+          data: { topic_id: topic.get("id") }
-function initialize(api, container) {
+function initialize(api) {
   // You can't act on flags claimed by another user
   api.modifyClass(
     "component:flagged-post",
GitHub
