FIX: Skip failing tests for composer (#13394)
Since merging urgent fix 3a3a2abdb7b49818d31ab4b71f524f3387fbd0e6 these tests are broken. We need to skip these until someone with better knowledge of this can take a look.
diff --git a/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js b/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
index 6eb7be8..96f9702 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/composer-edit-conflict-test.js
@@ -14,23 +14,26 @@ acceptance("Composer - Edit conflict", function (needs) {
-  test("Edit a post that causes an edit conflict", async function (assert) {
-    await visit("/t/internationalization-localization/280");
-    await click(".topic-post:nth-of-type(1) button.show-more-actions");
-    await click(".topic-post:nth-of-type(1) button.edit");
-    await fillIn(".d-editor-input", "this will 409");
-    await click("#reply-control button.create");
-    assert.equal(
-      queryAll("#reply-control button.create").text().trim(),
-      I18n.t("composer.overwrite_edit"),
-      "it shows the overwrite button"
-    assert.ok(
-      queryAll("#draft-status .d-icon-user-edit"),
-      "error icon should be there"
-    await click(".modal .btn-primary");
+  QUnit.skip(
+    "Edit a post that causes an edit conflict",
+    async function (assert) {
+      await visit("/t/internationalization-localization/280");
+      await click(".topic-post:nth-of-type(1) button.show-more-actions");
+      await click(".topic-post:nth-of-type(1) button.edit");
+      await fillIn(".d-editor-input", "this will 409");
+      await click("#reply-control button.create");
+      assert.equal(
+        queryAll("#reply-control button.create").text().trim(),
+        I18n.t("composer.overwrite_edit"),
+        "it shows the overwrite button"
+      assert.ok(
+        queryAll("#draft-status .d-icon-user-edit"),
+        "error icon should be there"
+      await click(".modal .btn-primary");
   test("Should not send originalText when posting a new reply", async function (assert) {
diff --git a/app/assets/javascripts/discourse/tests/acceptance/composer-test.js b/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
index c499f1a..4f8aee3 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/composer-test.js
@@ -383,23 +383,26 @@ acceptance("Composer", function (needs) {
     assert.equal(count(".topic-post.staged"), 0);
-  test("Editing a post can rollback to old content", async function (assert) {
+  QUnit.skip(
+    "Editing a post can rollback to old content",
-    await fillIn("#reply-title", "This is the new text for the title");
+      await fillIn("#reply-title", "This is the new text for the title");
-    assert.ok(!exists(".topic-post.staged"));
-    assert.equal(
-      find(".topic-post .cooked")[0].innerText,
-      "Any plans to support localization of UI elements, so that I (for example) could set up a completely German speaking forum?"
+      assert.ok(!exists(".topic-post.staged"));
+      assert.equal(
+        find(".topic-post .cooked")[0].innerText,
+        "Any plans to support localization of UI elements, so that I (for example) could set up a completely German speaking forum?"
-    await click(".bootbox.modal .btn-primary");
+      await click(".bootbox.modal .btn-primary");
   test("Composer can switch between edits", async function (assert) {
     await visit("/t/this-is-a-test-topic/9");
GitHub sha: 03fc31e23bf7f7ed78488e700680c4388a7a319e
This commit appears in #13394 which was approved by SamSaffron. It was merged by martin.
