FIX: Skip migrating null/blank custom field values in migrations
diff --git a/db/migrate/20200728222920_create_discourse_voting_votes.rb b/db/migrate/20200728222920_create_discourse_voting_votes.rb
index 9035349..0e3633e 100644
--- a/db/migrate/20200728222920_create_discourse_voting_votes.rb
+++ b/db/migrate/20200728222920_create_discourse_voting_votes.rb
@@ -15,6 +15,7 @@ class CreateDiscourseVotingVotes < ActiveRecord::Migration[6.0]
       SELECT value::integer, user_id, 'false', created_at, updated_at
       FROM user_custom_fields
       WHERE name = 'votes'
+      AND value <> ''
       ON CONFLICT(user_id, topic_id) DO NOTHING
     SQL
@@ -23,6 +24,7 @@ class CreateDiscourseVotingVotes < ActiveRecord::Migration[6.0]
       SELECT value::integer, user_id, 'true', created_at, updated_at
       WHERE name = 'votes_archive'
+      AND value <> ''
     SQL
diff --git a/db/migrate/20200729042607_create_discourse_voting_topic_vote_count.rb b/db/migrate/20200729042607_create_discourse_voting_topic_vote_count.rb
index 4a24625..ff59571 100644
--- a/db/migrate/20200729042607_create_discourse_voting_topic_vote_count.rb
+++ b/db/migrate/20200729042607_create_discourse_voting_topic_vote_count.rb
@@ -14,6 +14,7 @@ class CreateDiscourseVotingTopicVoteCount < ActiveRecord::Migration[6.0]
       SELECT topic_id::integer, value::integer, created_at, updated_at
       FROM topic_custom_fields
       WHERE name = 'vote_count'
+      AND value <> ''
     SQL
GitHub sha: 835b3580
What about sites that have already ran this migration before this change? Do we need another migration to clean up these blank values or is it not really an issue?
This change is to deal with sites which had corrupt custom fields. For example:
For sites with bad data, the migration was failing with
ERROR:  invalid input syntax for type integer: ""
So if the migration already succeeded, the data is already valid, and I don’t think we need to do anything :smiley:
