FIX: skip some checks for CJK locale in TextSentinel (#7322)
diff --git a/lib/text_sentinel.rb b/lib/text_sentinel.rb
index e9b5232..4c5e92a 100644
--- a/lib/text_sentinel.rb
+++ b/lib/text_sentinel.rb
@@ -69,12 +69,18 @@ class TextSentinel
     @text.gsub(symbols_regex, '').size > 0
+  def skipped_locale
+    %w(zh_CN zh_TW ko ja).freeze
+  end
   def seems_unpretentious?
+    return true if skipped_locale.include?(SiteSetting.default_locale)
     # Don't allow super long words if there is a word length maximum
     @opts[:max_word_length].blank? || @text.split(/\s|\/|-|\.|:/).map(&:size).max <= @opts[:max_word_length]
   def seems_quiet?
     # We don't allow all upper case content
     SiteSetting.allow_uppercase_posts || @text == @text.mb_chars.downcase.to_s || @text != @text.mb_chars.upcase.to_s
diff --git a/spec/components/text_sentinel_spec.rb b/spec/components/text_sentinel_spec.rb
index e704f6d..c9db707 100644
--- a/spec/components/text_sentinel_spec.rb
+++ b/spec/components/text_sentinel_spec.rb
@@ -95,6 +95,16 @@ describe TextSentinel do
       expect(TextSentinel.new("去年十二月,北韓不顧國際社會警告")).to be_valid
+    it "skips uppercase text for CJK locale" do
+      SiteSetting.default_locale = 'zh_CN'
+      expect(TextSentinel.new("去年SHIER月,北韓不顧國際社會警告")).to be_valid
+    end
+    it "skips long words check (`seems_unpretentious`) for CJK locale" do
+      expect(TextSentinel.title_sentinel("非常长的文字没有空格分割肯定会触发警告但这不应该是一个错误这个要超过五十个个字符" * 2)).to be_valid
+    end
     it "doesn't allow a long alphanumeric string with no spaces" do
       expect(TextSentinel.new("jfewjfoejwfojeojfoejofjeo3" * 5, max_word_length: 30)).not_to be_valid
GitHub sha: 9dd325f8
