FIX: slow mode dialog doesn't remember Enabled Until value (PR #13076)
GitHub
can we instead change the binding at the point of usage where it’s written to? (It’s probably in the .hbs file.)
Some nits, but the code should function as is.
Consider importing an existing fixture and patching up the fields that differ.
@riking good suggestions :+1: thank you!
