@jjaffeux you mentioned that aria-hidden="false"
is not recommended?
Would it be better to make this a “tagless” component and handle all this in the template? (using the new not
helper) Something like:
<div class="software-update-prompt {{if showPrompt "require-software-refresh"}}" {{if (not showPrompt) "aria-hidden='true'"}}>
Yes that would work I think. I had a quick talk with @martin this morning on what limitations he would face when trying to move to tagless.
@CvX @jjaffeux I tried to move to tagless but I ran into issues rendering the aria-hidden attribute with if
using the syntax provided. I get this error:
For aria-hidden, @jjaffeux said:
Also I think you should double check aria-hidden usage, AFAIK, only aria-hidden=“true” is valid and in the test I only see a check for element.getAttribute(“aria-hidden”) === “”
According to MDN Using the aria-hidden attribute - Accessibility | MDN aria-hidden="false"
is a valid value and is actually the default. However, under best practices Using the aria-hidden attribute - Accessibility | MDN it says aria-hidden is not even needed if visibility: hidden
is specified for the element, which it is.
I have now made this a tagless component and removed the aria-hidden attribute altogether.
:shipit:
