FIX: solution for pending migrations for bin/turbo_rspec (PR #8134)
Currently, if you try to run ./bin/turbo_rspec you will got that error There are pending migrations, run rake parallel:migrate
Reason for that is that command is running in development mode which includes plugins migration files in ActiveRecord::Migrator.migrations_paths:
["db/migrate",
 "/home/lis2/projects/discourse/plugins/discourse-details/db/migrate",
 "/home/lis2/projects/discourse/plugins/discourse-details/db/post_migrate",
 "/home/lis2/projects/discourse/plugins/discourse-local-dates/db/migrate",
 "/home/lis2/projects/discourse/plugins/discourse-local-dates/db/post_migrate",
A workaround solution would be to run the command with the TEST environment like RAILS_ENV=test ./bin/turbo_rspec
I want to propose in this PR to override migration_paths to check only Discourse core migrations.
GitHub
You’ve signed the CLA, lis2. Thank you! This pull request is ready for review.
Maybe this is a bit too harsh, maybe simply re-exec self if you launch turbo_rspec and ENV[‘RAILS_ENV’] is not test ? That way we can make turbo rspec work with plugins eventually if we want.
@danielwaterworth ?
This definitely used to work - I guess it was broken by rails 6. It’s entirely reasonable for TurboTests::Runner to set RAILS_ENV since the rails environment isn’t loaded in the turbo_tests root process. In which case, we shouldn’t need to specify that we want the test configuration on line 80.
We need to make some sort of call here, @danielwaterworth if you are uncomfortable with this hack feel free to close, if it is good enough for now merge it in :slight_smile:
Agreed, let’s not let perfect be the enemy of good.
